sketchism
Went for a Hillclimb today before and after putting the Hubsinks on one of my bikes for a real world reference
if you're just bored theres some wallabys, a snake and a wheelie in there somewhere too haha
With HubSinks installed sees a temp of 91C at the point the stock motor hit thermal cutoff at 124Cpeak&115 nominal
then at 67c at the bottom of hill with sinks vs 84 stock, on a 25 degree day riding 2km distance and ~400M elevation (average 15% grade)
The difference off-road or in general riding is more pronounced than a constant climb because of the increased rate of cooling between accel spurts
(vid is private because i probably should have used a private road but there wasn't one steep enough)
[youtube]OBuDcXyElvk[/youtube]
nice nice, im looking forward to your results with FF, i dare say you'll see a dramatic improvement over running them with no FF as well once you have it all dialed in!
litespeed said:Without using ferrofluid yet I noticed my motor just cooling down faster than it was before while stoped and temps slightly lower than before also while running. I got a smaller freewheel and waiting on the tool to remove the one that is on there.....thus my delay.
It will be soon. I was hitting the single tracks pretty hard on Sunday and the bike stayed probably 10 degrees cooler than normal. Most times I'll hit 175 degrees and I was able to hit it three times hard at a peak of 165. The motor still peaks high but drops fast when off the throttle.\
