dan974 said:
would you show us your left side John plz ?
The left side is an aluminum cover, and all I did was cut a bunch of slots with an angle grinder and drilled a number of small holes, all as many as I dared without weakening the cover too much, but allow as free an intake as possible. The blades with exhaust holes (in this case slots) immediately behind the blades and the side facing piece of the very thin angle iron which largely prevents air rushing in from the side to fill in the low pressure region created as the blades fling air off edges are what is important. That's how centrifugal fans work. ie The blade flinging air off the tips creates low pressure behind it, and in this case a large portion of the air to replace flung off the perimeter comes from inside the motor. I can clearly feel the greater wind thrown off that side of the tire from over half a meter away.
I'm now running the hubmotor at over 25kw peak input and the stator has yet to get over 85° no matter how I ride. At some point I'll try adding a ring to block the open slots in the rim to prevent flow from the left side to the right on the outside of the motor, because that flow is substantial which I saw during the smoke test. As we got the smoke output tube near the perimeter of the side cover we could see it clearly suck the smoke outside of the shell to the other side. Blocking that should greatly increase flow thru the motor.
If I wanted even more flow, then I would install an air dam on the left side. The idea would be to slow the flow of air from the moving bike that is flowing at a right angle to the direction of intake. Slowing that air flow immediately outside of the intake will increase the pressure, making flow into the motor easier. The trick would be to make such a duct/dam so it doesn't deflect sand and rocks at the side cover to get more easily sucked into the motor.
I already have air scoops on both sides of the swingarm which direct considerable air toward the motor when riding at high speed with minimal effect on aerodynamics. I should probably block off the scoop on the right side, since I don't need to add to the outside air pressure on the exhaust side, or at least deflect it somewhat upward to create greater velocity at the blade tips at the top of the rotation. It's working so well that I'm not very motivated to make changes. The right and left scoops are identical. Here's a pic of the right side before I vented the motor:
PS- I'm about to vent a couple of more motors using what I learned on this one. I'll document it much better and give it its own thread with plenty of pics as soon as I'm sure my new adjustments are an enhancement in both ease of build and improved function. I expect it to be my recommended approach that can be applied to any hubmotor with only the high load low rpm guys needing to go with active fans in addition to these passive blades.
