famichiki has measured some sizes heresuppi said:.....
How thick are those pads supposed to be for it to contact the outer cover? ....
raylo32 said:And I have yet another idea, trying to come up with something easier than trying to shape hard pieces of alu or copper to fit under the case. How about metal BBs, poured into a piece of MTB innertube with the ends sealed. Then wrapped around the motor and held on with a zip tie. Thinking that if filled and fitted correctly this might be squishy enough to form fit into the gap as the cover is installed. Maybe another small bag on the ends. I ordered some BBs and might give this a try next week. Yes, I know the rubber will be somewhat insulative but with pressure and decent contact it might be transmissive enough. And the sub 100C temps we are talking about won't be enough to melt the rubber.
hemo said:I see copper scouring type pads are being utilised to fill some of the larger air voids where thermal pads may prove to be not so good, what are folks thoughts about rolling up and and mashing aluminium foil into shape to fit these larger air voids or even clean old aluminium take away trays/cartons ?
gordone said:When you install the temperatur sensor, is it recommended to use conformal coating for protection from weather?
https://www.ebay.com/sch/i.html?_nkw=Conformal+coating&_trksid=p2380057.m4084.l1313
scianiac said:Where are you putting the thermistor? It should be mounted to the motor so it's inside the sealed case and shouldn't need any waterproofing. Not that it will hurt, although most thermistors are sealed anyway.
It all depends how and what you use for better heatconductivity.bpratl said:What is the safest motor housing temperature, with and without thermal inside packing?
I would like to add an external temperature sensor, on the motor casing, because I do not
want to disable the Throttle by adding an internal sensor. Thanks,
I must say it sound interesting, but reading the linked blog, I think it isn't that simple and a lot of work for only an estimation of the temperature and I wonder if you can determine the resistance accurately enough with just 8bits.dzid_ said:.....
......Or am I overcomplicating this? Because if we can (sometimes) measure winding resistance then we know the winding temperature, which is what we are really interested in. .....
+1pxl666 said:...
do you have exact length and width of aluminium pieces ?
Indeed it will better, because the heaconductivity from aluminium is a lot better.pxl666 said:i used fat thermopads and added radiators to case , but i'll go your way , i think it's better ...
Because the heat dissipation is improved, you keep the motor temperature lower, which has a postive influence on the function of the motor.GrampaPete said:With Eco Cycles supplying a heat sink, is there any particular reason to set max power to 450 as suggested in the V4 OSF instructions? Can you safely go higher?
pxl666 said:do you have exact length and width of aluminium pieces ?
thanks sirstratohunter said:pxl666 said:do you have exact length and width of aluminium pieces ?
Just measured them today. My "middle brace" is 162mm long, 33mm high and 1.2mm thick. My "outer brace" is 196mm long and 29mm high, and has a trapezoid cross section, being 0.4mm thick on one side and 1.3mm on another. But again that's rough handcraft and the motor casing is known to have variations, so take it with a grain of salt.
Elinx said:On a Polish forum about Tsdz2 I found a very nice comparision of the use of different materials.
It isn't the same as using the tsdz2 under different conditions like off road or long runs with high speed on flat roads, but because the measurements are all made under the same conditions you can see how much they differ.
The measurements are done by markkar
The results:
Tsdz2 stock 81°C / 178°F max.
Tdsz2 with heat pads 63°C / 145°F max.
Tsdz2 with aluminium shims 54°C / 129°F max.
Tsdz2 with aluminium shims and heatsinks 53°C / 127°F max.
As you can see the use of heat pads does help a lot (-18°C), but the use of aluminium shims is even better (-27°C)
Adding heatsinks for better airflow helps a bit, but the difference isn't that big.
SOURCE
pxl666 said:Elinx said:On a Polish forum about Tsdz2 I found a very nice comparision of the use of different materials.
The results:
SOURCE
this guy is selling thermally modified motors. ready to go
I'm only interested in his comparision.pxl666 said:this guy is selling ....
Exactly this is described in the wiki (step 2) tooornias said:.....
- By just adding some conductivity between the motor housing and the stator-ends (pads, plates+glue), combined with the top and bottom cooling plates. We could significantly affect cooling rate. As the heat from the stator ends gets vented right at the stator ends itself
Elinx said:I'm only interested in his comparision.pxl666 said:this guy is selling ....
Of course the results could be manipulated for commercial use, but his comparision looks legit
pxl666 said:wouldn't the best solution to this to just fill housing with oil ? or machine fills from aluminium that ,with some thermal paste , ensures full heat transfer from windings to cover . I also considered drilling holes in both sides of cover to let the air flow but then motor would must have been sprayed with water repellent lacquer and I'm not really fond of these ...
Topic starter andrea_104kg did a sort of this in 2019 :wink: . He share his results there too.Piper J3 said:Has anyone tried cutting inlet and exit air ventilation holes in motor side cover? ....
