okashira
fechter said:Yes, these were exeptionally good at high rates. This is a sealed AGM type.
I wanted to install a diode so I don't need to worry about inductive spikes. I made one from a pair of FETs I had lying around. The gate and source are shorted so the FET is off, and we are using the intrinsic body diode. FDP8860 are only good for about 500A each. Later I found some IRFB7430 which have a body diode pulsed rating of 1,576A each! That should be enough. I could have bought some diodes, but I had FETs in stock and they might actually perform better than most diodes in this application.
I just took the FETs and snipped off the middle (drain) leg. The remaining legs just get soldered together. Pretty much all FETs in this package have the same pin out.
Diode Assembly:
Connection detail:
Does the FET neet to turn on to conduct with configured like that? sorry I am not familiar with this use.
I wonder if it might have some delay compared to a normal Schottky diode. You need the diode to conduct as quickly as possible to help.
I guess it should be pretty fast. I understand how it works now
Turn on should be typical for a MOSFET, pretty fast... enough to help at least
