Ykick said:Looks like the 9spd cassette's giving you trouble aligning the hub into the frame? Dishing the rim enough will probably leave spokes on the cog side nearly vertical as it's built?
And/or, relace the wheel offset spokes in the hub flange? I'd probably use a different rim at that point - Alex, or something with eyelets, at minimum.
You should also use a thin steel washer inside the LH dropout IMO.
I did think of that. But left it red for safety reasons to identify pos and neg wiresmotomech said:athletic91-
If you replace the red wires with black, it will look much less like an Ebike(if you care).
You can still either 1) wrap the entire harness in electrical tape, or 2) undo the connectors, slide some heat shrink on, and redo the connectors. They don't make any black bullet connectors? WTF - Andersons all the way, always.athletic91 said:I did think of that. But left it red for safety reasons to identify pos and neg wires
athletic91 said:5000km update.
Sometimes at high wattages i can hear hub gear slippage for 0.5 secs of grinding sound, other than that its fine. I will gladly replace the the cute100 at the 8000km mark .
