Lebowski said:
Hm, strange. are you still using 1.5 for option j or did you make this one 0 ? (recommended !). The 60 should be fine but the 1200 is high (will introduce a lot of noise), I would try 300 instead...
The 2.40 has support for temperature sensors and can throttle down (limit the phase current) automatically if the sensors get too hot.
I set option j to 0 when we reran the test. Unfortunately we ran out of testing time due to making too much noise on a Saturday. Spinning a big propeller is not a quiet experience
I'm looking forward to the features in the new version.
I'm not sure why I have to set the amplitude settings so high, but it does function. I need more test stand time to figure things out. The controller still conks out to Drive Mode 0 with very rapid throttle movement, but it can restart after the motor comes to a complete stop with the settings I posted. Unfortunately I had no time to test the flying restart option.
The settings you posted would cause a fault to occur on the gate drivers which most likely signifies an over current event of some sort. I latch the controller off when the gate driver signals a fault which requires a power cycle to restart.
I need more time on a test setup to improve the tuning. I'm really happy that I succeeded in finding a power rating for my controller. I believe it is also capable of short 20kW bursts @ 100V, but with a normal Cromotor I've only been able to get ~170A bursts because I don't have enough load / saturating the motor.
On the 12.5kW runs we saw sustained 150A phase currents which is 50A per MOSFET. The temps only made it into the low 60C range after 2 mins of run time and they started off in the 40C range due to previous testing. We were unable to perform some of the thermal / power testing I wanted to due to not having remote temperature read outs.
I did manage to get some good info on the internal case temp vs MOSFET case temp. Using a FLIR gun I was able to see that there was a delta of about 4C between the MOSFET case temp and the external enclosure temperature after server minutes of running.
I created this controller with the plan of having a high burst rating compared to continuous running conditions. I used a 0.25" thick aluminum heat spreader bar to add thermal mass before it interfaced to the case which has small heat sink fins on the top.
