pendragon8000
There is another phenomenon I have experianced and thought it may be sag dropping below lvc on full throttle take off, so I tested on full charge and it still cut out... so what was it? Well with the same crystalyte you have as me it would go into throttle over voltage cut out on hard take off. So I set my throttle out Max (on the CA v 3) to .2v less and it was fixed. So it seems the comparitive voltages change enough in the controller to make it see the throttle as too high when under high load.
Good luck.
Good luck.
