tomtom50 said:High quality steel frames work. I built mine on a Trek Reynolds 531 touring frame. Taste varies but I think the old lugged frames look and ride great, nicer than most aluminum frames. As for weight ebikes weigh more, but it matters less because the motor is stronger than the rider. How important is a three pound weight difference between a top-rate steel frame and a carbon frame?
From the standpoint of Tongsheng enginneers they had pretty clear design criteria for a marketable system:
1. Wide frame compatibility
2. Reasonable chainline (50mm or less) with a gear drive and torque sensor fitted in
The decision to fit to 68mm and 73mm bottom brackets is fine, those are the most common by far.
The engineers dished the back of the drive side housing to reduce chainline. If they hadn't done that it might fit some carbon frames, but the chainline would be worse for a larger number of installations.
I'm glad they compromised as they did they did. On a typical frame 50mm chainline is about as much as is acceptable before there are significant issues on the inside rear cogs.
raylo32 said:Question for my fellow TSDZ2 owners... The main motor power wires that come out of the housing seem very small gauge to me, like maybe 16 ga, for 750 max watts and the corresponding amps. I am running 12 ga wire from the battery but not sure of the value in that considering the downstream 16 ga. Are all these motors supplied this way?
imfrommexico said:tomtom50 said:High quality steel frames work. I built mine on a Trek Reynolds 531 touring frame. Taste varies but I think the old lugged frames look and ride great, nicer than most aluminum frames. As for weight ebikes weigh more, but it matters less because the motor is stronger than the rider. How important is a three pound weight difference between a top-rate steel frame and a carbon frame?
It's not totally about the weight ...
aesthetically, there are no more welds on the frame and the shapes are more developed
It's also possible with carbon frame to pass all the cables internally
and with carbon , you have really really more reactivity , i like rigidity bike.
And yes , when you ride , 3 pounds weight is not a lot, but when you have to regularly carry your bike , it matter
But I totally understand the standpoint of Tongheng , of course the current design are more marketable and give more frame compatibilty .
sorry for approximative english speaking
tomtom50 said:Antenor said:Thank you for the explaniont
Do i need some sort of special cable to flash the firmware?
I saw the open source software, but it looks more complicated that i can handle
See
https://www.eco-ebike.com/blogs/eco-cycles-instructionals/tsdz2programmingfromscratch
Shows how to make the cable and connect. And it has firmware files
And the 2nd video
https://www.eco-ebike.com/pages/videos
Tells you how to flash the hex file.
It is easier than doing the open source firmware.
I know where you are coming from with your questions. Information is spread over this thread, which is now at 173 pages! Some is contradictory, some is not incorrect but someone else found a better solution.Strider said:I'm actually also wondering this, it's not that clear what kind of cables you need to buy.
From what I've understood, please correct i'm mistaken:
Here is my attempt at a comprehensive tutorial for installing Open-Source firmware with KT-LCD3 and also flashing stock firmware.. Revise as you like. I hope it works for others.Antenor said:That would be great![]()
The information is too spread over the topic
Thanks Bigwheel. I don't have that narrow /wide Bafang gear that you show. Maybe it's the BBS02 part? I saw one guy with a belt drive that looked like the 130mm rings would clear the housing. My kit just shipped today so I don't have anything I can measure yet. With the internal gear hub the chainline won't be changing all the time. But the single speed chains like to run straight I've been told.Bigwheel said:I adapted an offset Bafang style 46t chain ring to the TSDZ2 spider to improve my chainline.
It has to be a 46t though to make it over the reduction gear housing and you have to be precise shimming it as too close in will scrub the plastic cover. Made a big difference in chain life as I use the bike primarily as an mtb and spend a good amount of time in the lower part of the gear range.
tomtom50 said:Here is my attempt at a comprehensive tutorial for installing Open-Source firmware with KT-LCD3 and also flashing stock firmware.. Revise as you like. I hope it works for others.Antenor said:That would be great![]()
Open Source and Stock Firmware Tutorial.doc
Thank you tomtom50 for this. I've actually customized the stock firmware and I also like it as it is.tomtom50 said:On the other hand, purely functionally, the stock firmware is quite good. Don't expect the open source firmware to give a radically better riding experience or to dramatically extend battery life.
InterestingBigwheel said:I adapted an offset Bafang style 46t chain ring to the TSDZ2 spider to improve my chainline.
tomtom50 said:InterestingBigwheel said:I adapted an offset Bafang style 46t chain ring to the TSDZ2 spider to improve my chainline.
Did you need to fabricate a spider or does the chainwheel mount directly to a TSDZ2 spider?
Can you give a link to the chainwheel you used?
What is the chainline you get in the end (stock TSDZ2 is 50mm)
feketehegyi said:Thank you tomtom50 for this. I've actually customized the stock firmware and I also like it as it is.tomtom50 said:On the other hand, purely functionally, the stock firmware is quite good. Don't expect the open source firmware to give a radically better riding experience or to dramatically extend battery life.
I've already removed the XH-18 as well and given the following default values to stock firmware:
- 20" wheel size
- 45Km/h max speed
So, now I just switch it on with a switch and ride it immediately.
- Assist level 3
I only use my mobile with bluetooth connection, if I would like to use a different assist level or curious on voltage, watts, etc.
raylo32 said:Not strictly related to the Tongsheng drive but I made an EGO battery mount and installed it on my bike. It accepts the 56V (really 52V) EGO tool batteries. I have a couple of their 5Ah batteries for an underused EGO battery powered snowblower. These should be good for shorter rides or to carry along as a spare for longer rides.
https://www.thingiverse.com/thing:3415459
Rydon said:feketehegyi said:Thank you tomtom50 for this. I've actually customized the stock firmware and I also like it as it is.tomtom50 said:On the other hand, purely functionally, the stock firmware is quite good. Don't expect the open source firmware to give a radically better riding experience or to dramatically extend battery life.
- 20" wheel size
- 45Km/h max speed
- Assist level 3
Very cool feketehegyi! Is this hack something you could share? The TSDZ2 lends itself to stealthy rides and I'm sure there are many including myself that would like to do this. Is adding bluetooth required?
Peetsyo said:Hi,
I cannot use the motors torque arm to hold the motor in position , so maybe I can drill holes into the gear housing and fix the motor to frames chainguide mount (ISCG-05). I've got a full suspension frame , that's my only option.
Cheers !
Corrected error that 6-pin TSDZ2 doesn't support brake connectiontomtom50 said:Here is my attempt at a comprehensive tutorial for installing Open-Source firmware with KT-LCD3 and also flashing stock firmware.. Revise as you like. I hope it works for others.Antenor said:That would be great![]()
