ancan said:cafu02 said:ancan said:Hi,
After about 50km with the original firmware, I got a package from Singapore yesterday, with the things needed for the Open Source f/w upgrade, Reprogramming the display was trivial, but the motor caused be issues with constant read errors and programming failures, and after an hour of shortening cables and cursing I gave up, and thought it was caused by my crap ST-LINK V2 adapter.
However, on my desk was sitting the spare controller I bought to get some contact or whatever from, and I though I'd give it a try. Surprisingly, the ST-LINK had no problems whatever talking to this controller, and I've read and written firmware multiple times to it without issues.
So naturally I replaced the orginial controller with this one, and just did a quick test to confirm it's working, and so far so good! Apparently programming issues can be hit-an-miss not only depending on which ST-LINK adapter you're using, but also vary from controller to controller, so I'd recommend anyone that plan to do this to go with the extra controller option. I don't remember what I was supposed to steal from the extra controller (everything's connected without cannibalizing any controllers), but glad I bought one.
TLDR: Programming failures can be related to the individual controller as well as the ST-LINK V2 adapter and wire-lengths.
Thanks for the updated information.
I Have my motor which has the 6 Pin connector without throttle and breaks
I'm looking to order the parts needed to completed the FOS Firmware.
Where did you purchased the kit needed
Thanks
I got it from pswpower.com, except the ST-LINK V2 that I got from eBay seller "nouteclab"
* ST-LINK V2 (Different pinout than the one used in the wiki).
* KT-LCD3
* Controller
* Extra speed sensor for the contact used for programming.
* (And a bronze gear just in case the blue breaks).
Perfect
Thanks much
Going to order some parts
