eyebyesickle
Nice. I have not tried heat sinks yet but have been experimenting and am about settled with thermal pads around the motor like that!
ezrider1199 said:Hi, I was trying to install an accessory front light (DIY) and seeing some strange stuff. When the LCD3 light is on, the accessory voltage is 2v however when LCD3 light is off the voltage is jumping around 6-9v. And when the LCD3 light is off, i plug in my light the voltage just drops to 0. Is this normal?? I'm pretty puzzled by this, especially since my light works fine via a bench power supply (tested 4-10v)...
The lights are dual LEDs that i had them wired in series at first and then in parallel. The series didnt work out because the first light was taking all the voltage i assume. But the parallel should work (tested via bench power supply). I hope i didnt mess anything up... rest of the bike works A+
mctubster said:ezrider1199 said:Hi, I was trying to install an accessory front light (DIY) and seeing some strange stuff. When the LCD3 light is on, the accessory voltage is 2v however when LCD3 light is off the voltage is jumping around 6-9v. And when the LCD3 light is off, i plug in my light the voltage just drops to 0. Is this normal?? I'm pretty puzzled by this, especially since my light works fine via a bench power supply (tested 4-10v)...
Sounds strange. Never seen this. When off there is a small floating voltage, nothing that would power a light. When on just over 6 volts. On your bench power supply what is the current and voltage you are using to drive the lights? This circuit only supports a few watts.
I have never tripped the light circuit, but from previous comments it appears to cut out and then reset when the load is removed.
QuirkyOrk said:Here in Boston we just had the hottest July on record, so I took it upon myself to do a thermal management mod for the TSDZ2. I was routinely having to dial back my assist usage to stay below 75C on my 23 mile (37km) round trip commute so I decided I would do something about the TSDZ2's awful thermal management (Love the motor overall though).
What I ended up doing was two things...
-I filled the air gap around the motor with a thermally conductive silicone pad so that it now has something to shed the heat to the outer casing other than a not very thermally conductive pocket of air.
-I attached some aluminum fins to the casing of the TSDZ2 so it will cool down quicker. To do this I sanded down the casing to the bare aluminum and then attached some aluminum electronics heatsinks with a thermally conductive epoxy. These work very well as there is constantly air flowing by the bike as it moves through the forward.
These two things have made a huge difference. I pushed the motor extremely hard on my commute yesterday at 4x power multiplier and it never got above 58C. Before when I would use the bike at a much lower assist level I would be right below 75 by the time I got to work.
I attached some crappy phone pictures below. if there is enough interest I could do some DIY instructions, but overall it was not a very complicated process.
IMG_20190807_104330 copy.jpgIMG_20190806_205516.jpgIMG_20190806_205509.jpgIMG_20190806_202748.jpg
ezrider1199 said:dameri said:Where I can find this axle? It’s blue gear axle which goes to big gear.
I asked PSWPOWER but they don’t have it.
Maybe this will help. I searched for TSDZ2 shaft here's a result, https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20190808094810&SearchText=tsdz2+shaft&switch_new_app=y
buba said:Alpha 3 is live!
QuirkyOrk said:,,,,,, TSDZ2's awful thermal management.......
............ two things...
-I attached some aluminum fins ...........
These two things have made a huge difference. .......
Nice to see these solutions seems to have a positive result.eyebyesickle said:........... have been experimenting and am about settled with thermal pads around the motor like that!
I'm in South FL so I need to do something with my TSDZ2. It's nice to know this simple mod works. I was planning something more elaborate, but if this gets the job done then why not. Thanks for posting your results.QuirkyOrk said:Here in Boston we just had the hottest July on record, so I took it upon myself to do a thermal management mod for the TSDZ2. I was routinely having to dial back my assist usage to stay below 75C on my 23 mile (37km) round trip commute so I decided I would do something about the TSDZ2's awful thermal management (Love the motor overall though).
Elinx said:QuirkyOrk said:,,,,,, TSDZ2's awful thermal management.......
These two things have made a huge difference. .......Nice to see these solutions seems to have a positive result.eyebyesickle said:........... have been experimenting and am about settled with thermal pads around the motor like that!
I wonder if it is sufficient enough to stick this thermal silicone pad only into the casing on the flat side, so after tightening the screws of the casing the metal of the motor-front makes thermal contact with the casing. (no thermal pads around the motor)
In that case it is easier to service the motor afterwards.
Retrorockit said:I'm in South FL so I need to do something with my TSDZ2. It's nice to know this simple mod works. I was planning something more elaborate, but if this gets the job done then why not. Thanks for posting your results.
The tight fit between the pads and case is important. The more pressure the better the heat transfer. It also helps that they're malleable and can conform to the uneven surface of the motor.QuirkyOrk said:Retrorockit said:I'm in South FL so I need to do something with my TSDZ2. It's nice to know this simple mod works. I was planning something more elaborate, but if this gets the job done then why not. Thanks for posting your results.
Thanks for the kind words. Yeah I tried to keep it as simple as possible. I wanted to keep the sealed casing and weatherproofing of the motor intact because using the bike rain or shine is very important to me. I also realized that passive cooling would totally get the job done in addition to being nice and simple.
If you use our OpenSource firmware, we can help as it provides technical real time data of motor and sensors.cejean said:I Think i have broken my controller or motor after greasing the bleu gear….![]()
After greasing i build it all together and started up the TSDZ2.
Everything looked oke, but when i peddal there was no support anymore en get E004 error on display...
Very strange numbers in display like 97 km/ hour till zero km / hour.
I checked the speedsensor and everything looks oke.
I opened the motor and the only thing i noticed was that i forgot to put the motor cables down in the clip.![]()
Some cables looks a kind of flat. They are not broken, i checked them and are oke….
I put new software on the controller and didn`t gave any results.
Now i don`t know how to search for the problem. I think myself there is a problem with the controllor or motor.
Is there a way how i can check the motor or controller to check if they are oke?
Is there anyone who will help me to try to find the problem on my 36V 350W motor ? :wink:
ezrider1199 said:QuirkyOrk,
What thermal pad thickness do you recommend? i saw they start at 0.5mm and go up by 0.5mm increments. Thanks
In the link you gave I saw that these pads have a conductivity of 13 W/m-K, but for a priceRetrorockit said:On the topic of thermal pads.
Panasonic seems to have made a thermal pad with graphite fibers aligned vertically...........
dameri said:ezrider1199 said:dameri said:Where I can find this axle? It’s blue gear axle which goes to big gear.
Thank you for the link.
Elinx said:In the link you gave I saw that these pads have a conductivity of 13 W/m-K, but for a priceRetrorockit said:On the topic of thermal pads.
The cheap silicon pads about 2 W/m-K, that is a lot of a difference, but always better than air with 0,03 W/m-K
3M pads have a conductivity of about 5 W/m-K
Searching the web I found this and that material with a (given) conductivity of 12 and 12,8 W/m-K, but I don't know if it is useable for our function.
They're expensive in the pre packed 35x35mm individual size for electronics, but possibly much cheaper in the bulk 140x140mm sheets we would want. I haven't priced it yet. I will probably be buying this for my computer overclocking projects anyway. In the US 750W is a legal E bike rating. So 750W continuos is a legitimate target for us. I have an inquiry in to Panasonic tech support about this material, but they're on vacation until 8/20. They may not bother to reply to an individual anyway. I had been looking at copper foam, carbon foam, and solid metals like Copper. But the success of the DIY TIM pads got me looking onto this option. I may still look into doing a Copper solution. I haven't taken the cover off of my motor yet to measure things. I've been busy with a 7 to 8 speed IGH upgrade.Elinx said:In the link you gave I saw that these pads have a conductivity of 13 W/m-K, but for a priceRetrorockit said:On the topic of thermal pads.
Retrorockit said:They're expensive in the pre packed 35x35mm individual size for electronics, but possibly much cheaper in the bulk 140x140mm sheets we would want. I haven't priced it yet. I will probably be buying this for my computer overclocking projects anyway. In the US 750W is a legal E bike rating. So 750W continuos is a legitimate target for us. I have an inquiry in to Panasonic tech support about this material, but they're on vacation until 8/20. They may not bother to reply to an individual anyway. I had been looking at copper foam, carbon foam, and solid metals like Copper. But the success of the DIY TIM pads got me looking onto this option. I may still look into doing a Copper solution. I haven't taken the cover off of my motor yet to measure things. I've been busy with a 7 to 8 speed IGH upgrade.Elinx said:In the link you gave I saw that these pads have a conductivity of 13 W/m-K, but for a priceRetrorockit said:On the topic of thermal pads.
There is a possibility that if the heat can be removed directly from the laminated steel part of the motor ( where it's being produced) that cooling the end caps may not be needed. This would result in a lot less TIM material being used. I will do some measuring and see if some Copper pipe can be cut to cool just this area and use compressible TIM pads to attach it. But solving this problem with some $3 TIM pads is seriously respectable.
