Brlowe said:Can you display temperature on the SW102 display with the OSF?
Yes, use the same buttons as on 850C to select which variable to show on the numeric fields - see the wiki.hetm4n said:Brlowe said:Can you display temperature on the SW102 display with the OSF?
I join the question.
To compare with .....? All releases have pro and minor points. It is the user who must weigh these points.casainho said:Note that the firmware version of VLCD6 is outdated and has not the latest improvements so is not the best to compare.Elinx said:.........
So you can try OSF first and keep it if you are satisfied or flash the default FW back again, or replace the display if you want the latest OSF releases.
BeTon75 said:Hi, I have some troubles with my TSDZ2 and wonder if anyone can shed some light on the possible causes.
- First, the speed sensor broke, so I disconnected it and the TSDZ2 worked again, without speed limit....![]()
- Then, after about a year of trouble free usage, the display XH18 stopped working, but the TSDZ2 still worked, max power only
- After a few months, the TSDZ2 stopped working all together. It doesn't seem like a mechanical issue
How do I go about with trouble shooting? I already partly disassembled the motor to get access to the electrical stuff. Couple of things I think I need tot test, but how?
- Torque sensor, no idea how to test
- Direct connection between motor and battery to test if it still runs. Which wires to connect?
- Could it be that there a short in the speed sensor connector which prevents the motor to activate??
Thanks in advance for any suggestions!!
skestans said:I don’t know what’s the threshold in the EU. In Switzerland, shipments worth less than 62CHF don’t incur taxes.
skestans said:Em3ev has nice chargers, they send overseas, and they’ll put whatever value you want on the package. I got my 90/100% charger from them.
LJay said:skestans said:I don’t know what’s the threshold in the EU. In Switzerland, shipments worth less than 62CHF don’t incur taxes.
21% VAT is paid if the price is higher than 22 EUR and if it is higher than 150 EUR duty fees are paid also.
I looked at this web sites, but I wasn't able to find any charger as a separate item for sale (only as a bundle with motor and etc.)
Elinx said:It is also possible to use OSF with the default TSDZ2 displays, like VLCD6 too. All important personal settings are setup before flashing and you can use the bike the same way as before, but with a remarkable improvement.
(Latest stable is v0.19C, latest release is v0.20b1A)
Cristian said:BeTon75 said:Hi, I have some troubles with my TSDZ2 and wonder if anyone can shed some light on the possible causes.
Seems like the 3rd time the motor controller broke. That could be due to the max power (more likely related to the high current running) been ran all the time through it. The first thing i would do is order a new controller and then test.
matte2k said:Today after 6500km my Tsdz2 broke.
A light bang and the left crank went totally loose.
Took the crank of, see attached image.
Is there any future for my tsd? Is it possible to restore? I have another tsd with broken sensor I can take parts from...
Until this one is healed, or burried, i have a tsdz2 with foot brake on a second bike. Can I use this on my number 1 bike with only hydralic brakes (Bullitt cargo), or what could happen?
I can imagine what you mean. The main developers are Italian and don't work with Github. So you must be remain sharp to follow everything. So you are right it was less organized. It should now beiing a bit better, because stancecoke has given github support. The development is on par with KT lcd3 latest v.0.20, so that is not a problem.LJay said:......
I know about this option, but this project seems to get less development support than OSF and it´s little less organized also (I don´t want to offend anybody, it is just my impression). I would like to stick with original firmware for now, anyway.
beardydave said:Hi
Yes, I'm getting samples of upgraded bottom bracket spindles made from EN24 thru hardened steel, if they perform I'll get a small batch done. Email me at dave@revolvemcr.com if you're interested.
Cheers
Dave
skestans said:If not, I might be selling one of mine brand new, unused 90/100% chargers (still in the box)
LJay said:The issue is that the motor refuses to work with fully charged battery (54,2V), but when I discharge the battery down to 53,8V, it starts working fine then.
LJay said:Are there any available informations about how often this issues occurs, percentagewise? ...
Buy yourself an STLink and reprogram the voltage, its very easy and only costs a few EurosLJay said:LJay said:The issue is that the motor refuses to work with fully charged battery (54,2V), but when I discharge the battery down to 53,8V, it starts working fine then.
Are there any available informations about how often this issues occurs, prectagewise? I´m thinking about buying a new controller and swapping it for the old one, but it would be pointless in case the issue would be the same for a majority of available controllers on the market. In this case I will just buy/build adjustable charger and call it a day![]()
Cristian said:Does anyone know where i can buy a 52v battery in the EU? I have TSDZ2 with OSF running 48v and i want to upgrade to 52V and leave the 48V battery for my wife's bike, which will is also getting a TSDZ2 with OSF.
Should i upgrade to the 850C? Is it worth the cost? I'm on KT-LCD3 for 1 year and 2000km. Running so fine, it's been great, trouble free.
