An update on my 48v 18a 4000rpm installation as promised:
I ordered it with the xh18 display no throttle model.
My motor->cockpit cable was an Y cable. One connector went unconnected.
The seller told me this extra connector was for the throttle.
The display worked inconsistently. The seller said they delivered wrongly the 36v version and they delivered now for free the 48v version (attention, display is voltage dependent!!!). This one works sable.
I took the free delivery chance and also ordered the throttle, and it works (I was not sure it would, no breaks cables, I use it for testing) and a 52T (my original order was with a 42T). The seller said they will work in parallel.
The seller also told me that the most efficient rpm was 4000, that was the only wrong information so far. Wattage testing showed that under identical speed, a faster gear uses less wattage (of course this is what I expected)
As I implied, 52T and 42T chainrings work in parallel!!! The 52T is flat, the 42T is curved inwards towards the motor. That means the 42T improves the chainline about 0.5 cm. This curve works as a spacer, so and I can place the 52T next to it (still inwards from the spider). On the other side of the spider (same screw holes) goes the 52T chainring cover. The only problem was that now the 42T went further inwards (the width of the 52T) ant it touches the motor by as minimal fraction (you can see the marks on the 42T). But 5 thin washers on the 5 screws (inner side of the spider) corrects the issue
I also upgraded my 9speeds 11-32 to 11 speeds 11-50. On the hills I was very happy with the original set up, but on the speed side sometimes (not very often) I felt I needed one more speed (when cruising too easily at 35km/h)
As seen in the graphic above, just with the 11 speeds and the 52T I increased my max speed by 10km/h and I also considerately improved my performance on hills. The 42T gives me absurd hill performance which I do not need. I tested the parallel set up only for the community but I will stay 52T with 11-50 without front derailleur. This will also allow me to better optimize the chain length and have the 52T a little closer to the motor. Just the 42T thickness and the washers. Pity the 52T is not curved, maybe because it was the "parallel" version.
These are the chainline pics of 42T 9 speeds and 42T 11 spreeds. (BTW, the 11-50 worked out of the box with the Shimano M8000 long cage, no adapter needed, just the T screw down to its maximum was required)
And the watt meter from Ali Express that was posted here a while ago. I think I need a larger handlebar.
