manneokoko
1 W
- Joined
- Jul 28, 2012
- Messages
- 63
A problem with the smaller display might be that we don't know how to make hidden settings on it, since it doesn't have the same buttons as the bigger one. It looks pretty though.
manneokoko said:Anybody have tried the luxury display, XH18? looks like it has a throttle like selection of assistance level which I think would be very handy, no need to let go of the handles to change assist level.
manneokoko said:I have heard that with the bafang bbs engines, that they dont have enough grease in them from factory and that you should open them and put in extra grease before using them to improve the lifespan and durability.
Is it the same with the TSD2Z2 engine? If so, what type of grease and where to put it?
Thanks
manneokoko said:The front chainring is 42t, would it be good to have the smallest gear in the back to 11t? I want to pedal at comfortable cadence (not pedaling to fast) in about 35kph. The wheel size is 28".
So would 42t front, 11t back be a good combo for about 35kph speed?
DrewSki said:Ok, managed to get the motor out and the blue gear is bad. Now how do I get that blue gear off?
mscoot said:Please do explain how you did that. I'll be pulling this thing apart soon..
MPM said:Those four parkers are all that holds the motor, so you can pull/wiggle it out once the screws are undone. Don't hit the big brown capacitor on the way out!
There you can see the first gear reduction of the two.
