Garth
10 µW
Hi Folks,
just found this interesting posts here while searching for the repair manual of the TSDZ2 / DU250 Motor. There should be one somewhere outside in the internet. If someone got that, could he PN that to me ?
I got the German DU250 fittet to my trecking bike, geared with a 14Gear Rohloff Speedhub. It fits wonderfull to the TSZD2, really.
I did about 2000Km this year, of witch 500 are from one single trip getting me in 3 Days from my Home to Lage Garda in northern Italy.
205Km on the last Day, bringing me and my 1,4KWh 10s14p battery to the limit. The motor was doing his job!
Set to run without speed limit it draws a max of 12A, that seems to be reduced later to a max of 8A, I dont know why, perhaps a temperature limiting function as the motor does get warm while driving at 40Km/h .
Its the second motor already, the 1st one was replaced after about 700Km making a high frequent electronic noise when getting warm.
to make it short : The Motor is great, I can absolutely recommend. The only point on the negative side for me is it does not like high rpm on the Crank, even less when the voltage goes down, then it gets quite lazy. So for long distance now i "pump" from the big main battery to a smaler one via a DC-DC Converter to keep the smaler one always at 41V. That does the job.
I can confirm that "Jap" and 25A instead of 16A setting does not change anything as far as i can tell.
