AWD said:Definitely interested here! Thanks for the hard work.
Drum said:Coaster Brake version, Broken Torque sensor.
I recently received a TSDZ2 motor and a spare torque sensor assembly, for me to strip the motor and replace the sensor. It was assumed rather than known that the sensor was broken, so I fitted the motor to a spare mountain bike and tested it.
The display lit up, everything looked normal but on riding it there was no assistance at all.
On stripping the motor and removing the original torque sensor I found it was cracked in the tube that surrounds the pedal spindle.
Short story: Replacing the torque sensor fixed the problem and it worked well, however:
Long story: When I compared the broken sensor and the one I had been given to fit, they were not identical. The old one was shorter in the pedal spindle and in the tube that surrounds it, and it had two bearings on the left hand end of the pedal spindle. The new one had a longer spindle, longer tube and only room for one bearing.
The length from the mounting for the large gear to the circlip on the pedal spindle that retained the inner race of the lefthand bearing was the same on both.
If I had fitted the new assembly with only one bearing, it would have been able to slide sideways by the width of the bearing (7mm), so I machined up a spacer bush the same OD as the bearing and the same width. I slid this bush in before the bearing and tried to assemble. Weirdly, it seemed the bush was 1mm too wide, so I made another 6mm wide and everything assembled fine with virtually no side play on the spindle.
Looking at the photos of torque sensors for sale from various suppliers, they all looked the same as the newer (single bearing) one, so I assume the motor I had was an early one and the design has changed in later motors.
Another thing I noticed was that the big gear was solid, with no sprag clutch (one-way bearing) in the middle. This meant that the pedal spindle rotated with the chainring at all times, so if the motor was driving the chainring it was also driving the pedals.
I realized that this was almost certainly a "Coaster Brake" version of the motor, as pedalling backwards DID drive the chain backwards and would be able to activate a coaster (back-pedal) brake.
It also means that it would be very unwise to use a throttle with a coaster brake version of this motor!!
Test Riding the bike, I noticed that if I was pedalling hard, then stopped suddenly, I could feel the pedals "kick" forward briefly. Obviously it took a fraction of a second for the torque sensor / controller to sense that the pedal torque had dropped to zero and stop powering the motor. Not a major issue, but enough that I would prefer not to use the coaster brake version unless I actually needed that function.
Yes but you will need to get your hands dirty or pay to some local shop to do it for you.John and Cecil said:We will probably upgrade in the future to the lcd3. Does the lcd3 have a port for the throttle, a usb port, and also is there still a way to use the 6v light ports?
casainho said:Yes but you will need to get your hands dirty or pay to some local shop to do it for you.
Let's see:
1. Throttle: the throttle needs to be connected to comming wire from the motor controler and not to LCD3. This is just wire connecting, soldering.
2. USB port: there is a version of LCD3 with USB charging output but I never tested auch version. But should be like on VLCD5, an isolated module board just for that feature, inside the LCD.
3. 6V lights: just like the throttle, it needs to be connected to wires that comes from the controller. And the controler enables/disables that wire power when LCD sends a specific command to the controller - I will implement that, LCD3 has specific symbol for lights state, it is near the brakes symbol state.
As you see, is just wiring connecting, and don't even need to solder them. A multimeter tool is a must to validate the battery voltage wires.
AZUR said:I have felt something with the TSDZ2 motor that may be related to the reason why the current intensity is zero for a few moments.
I have a TSDZ2 with 350W 36V.
I felt that when I was pedaling continuously, on a road with a slight slope of 1%, the bicycle was working with sobs. It was as if the TSDZ2 engine briefly stopped assisting the pedal.
...In TSDZ2 it is as if the engine is making, sometimes, a counter force.
That is possible on the developement of our firmware, which I started already.jbalat said:Casaihno this is pretty obvious from the Watt output on the LCD3. Is there anyway we can smooth the torque input and stop it dropping to zero while the pedals are turning ?
casainho said:Go to github for the OpenSource firmware and you have there also for the 48V version.
So, first byte of EEPROM is the lower voltage limit. 2nd byte nominal voltage, all them divord by 2.5.
3rd byte the current in amps.
Did you try to change 3rd byte??
casainho said:I want to implement the Wh measurement for the current trip and the idea is that it will help me to understand how much battery energy is left.
My question for you guys: should I implement Wh or Ah??
Maybe Ah because we know how much Ah our batteries have and will be easy to compare than if we use Wh, right?
jbalat said:AZUR said:I have felt something with the TSDZ2 motor that may be related to the reason why the current intensity is zero for a few moments.
I feel this too. The 36v motor does not give a lot of assistance and when the battery is low or you use a lower assistance level then I can also feel that as you peddle the assistance is off or indeed backwards if only for a very short time.
I got that creaking too a few weeks ago. I think it boils down to sloppy bearings around the bottom bracket. There's probably enough play there to let the plastic cover on that one-way-bearing scratch against something. So by applying grease behind that central rubber cover you're only silencing the symptoms of sloppy bearings.
Here's an italian video describing how to remove that central bit:
https://www.youtube.com/watch?v=hqAP1NZvNPo
I'm not sure what sort of bearing sizes sit there. If they're standard sizes we could probably replace them with some proper, tight, high quality bearings from the local hardware shop.
Regarding the shims, I only used the ones that came with the kit, so I know nothing about the sizing. But I could fit two shims behind that circlip on the right side of the motor when it was brand new.
Seeing as you are in Sweden, you could probably just order them directly from my local (e)bike shop: http://www.strommenelsykkel.no/ . My impression is that he's got plenty of spares for this motor. Give him a call. He's a nice guy: http://www.strommenelsykkel.no/
The plastic washers are to go between the XH18 gripshift switch and your handlebar grip, to reduce friction while operating the gripshift switch.sysrq said:I have two plastic shims in the same bag with xh18 supplied by the manufacturer, are these supposed to go behind the crank spindle circlips? That seems weird, why haven't they installed everything already at the factory if there is such a significant play.
mglarocca said:Been studying up for a while and I'm excited to go for it on the tsdz2 52V 750W on a commuter build.
Do you all have a recommended vendor to buy a kit from for USA?
sysrq said:Still haven't tested it on the road, but developed some pulsing/throbbing hum which periodically becomes louder after replacing rubber pads between fixing block and hangplate while on walk assist mode. Seems like there wasn't any hum yesterday. Shame didn't tried it right before replacement. Might be due to misaligned casing or something, or vibration between chain stay and outer edge of the motor casing. Could wrap some rubber strip around the chain stay at the contact point and add some rubber gasket at the right side of bottom bracket as well, but then the chainlaine might get worse.
Actually the gap between chain stay an the outer edge of the motor casing is big enough so it doesn't need any damping. Had an idea of putting some silicone sealant between the outer shell of the bottom bracket and the inner part of the frame, but since the gap is neither wide enough or tight enough then the silicone would get spread around unevenly anyway.
