Hi,
Yes, got a bit curious back there. I attempted to open the end shields of the motor istelf, but the screws where really tight and I basically destroyed the first one I tried, so left it at that.
Interesting yours does not have the same noise without assist PhaenTa. I was suspicious my noise might be due to a worn chain, but simply turning the crank without chain attached produces considerable noise I think;
[youtube]b3d46RHingc[/youtube]
PhaenTa, or anybody else with a TSDZ2; could you make a recording and post? If it sounds very different it just might be I have received a bad sample.
Would be very interesting to see a current draw measurment indeed. I don't think the wires are that small, 2.5 mm^2 ? I guess it's important that the battery can deliver enough amps given the A setting is doing anything in the first place. The battery I tested with is said to deliver max 15 A, and is quite a cheap one. Don't know if it will deliver more on intermittent duty.
Cheers
Lars
Cheers
Lars
