Tonester said:First of all, I am new to this forum and have learned so much from all of you after reading EVERY page of this thread! It's taken quite a while but well worth the read. Many thanks to all the frequent posters (Eyebyesickle, Squee, RTII, Daytriker, etc) here for sharing their knowledge and enthusiasm for this very capable motor!
I'm planning to purchase 2 motors. I'll first install one on my wife's Trek hybrid bike with 700c wheels using the XH18 color display. She just wants a little assist for when she's tired or for uphill riding. Secondly (if I like the motor), I want to install one on my ICE Sprint trike using the VLCD5 display. I'm fairly sure I'll go for the 48V / 500W motor for the trike, but I'm not sure about what to get for her bike. In both cases, we will not use throttle, just pedal assist.
Should I:
- Save a few bucks and get her the 350W with smaller battery (8Ah) since she likely won't need 500W of power. She'll be going no more than 30 miles at a time mostly flat just a couple hills.
- Or spend a few extra bucks to get her the same system I will have with 11Ah battery in hopes of having more consistent builds between the two.
My concern is that she's never ridden an e-bike (age: early 50's) and I'm wondering if the 500W might scare her more than the 350W motor? Do you think the 500W will provide more torque (assist) at each of the levels than the 350W? Or will the torque simply be proportional to pedal effort regardless of voltage? She'll likely ride on level 1 most of the time with the occasional boost going up hills.
Another reason I might want the same motor for her is if she doesn't like the motor, I can then just move it over to my trike and be done with it. Battery mounts will likely be different, so it's not really a benefit to swap batteries between them (unless I find a clever way to use the same battery mount).
Can we share the same charger if I opt for 36V for her?
Thoughts on pros/cons of these choices? Thank you!
They are if you use a Cycle Satiator.eyebyesickle said:The 36v and 48v CANNOT use the same charger - FYI!. 36v li-on batteries charge to 42v max, and the 48v batteries charge to 54.6v max, so the charger are not interchangeable.
atomohodez said:eyebyesickle, Bare Controller with Connectors for TSDZ2 TONGSHENG MID DRIVE MOTOR
will you have on sale this controller separately for 52v 18A?
Tonester said:I'm planning to purchase 2 motors. I'll first install one on my wife's Trek hybrid bike with 700c wheels using the XH18 color display. She just wants a little assist for when she's tired or for uphill riding. Secondly (if I like the motor), I want to install one on my ICE Sprint trike using the VLCD5 display. I'm fairly sure I'll go for the 48V / 500W motor for the trike, but I'm not sure about what to get for her bike. In both cases, we will not use throttle, just pedal assist.
Tonester said:Should I:
Tonester said:Another reason I might want the same motor for her is if she doesn't like the motor, I can then just move it over to my trike and be done with it. Battery mounts will likely be different, so it's not really a benefit to swap batteries between them (unless I find a clever way to use the same battery mount).
Tonester said:Can we share the same charger if I opt for 36V for her?
Best purchase I made in eBike gear. One charger for my 36V, 48V, and 52V batteries. Also I can choose any percentage of charge level for all and change the charge rate to the max allowed by the BMS. Doubling battery life is another high point of the Satiator!amberwolf said:They are if you use a Cycle Satiator.eyebyesickle said:The 36v and 48v CANNOT use the same charger - FYI!. 36v li-on batteries charge to 42v max, and the 48v batteries charge to 54.6v max, so the charger are not interchangeable.
Should I:
Tonester said:Mostly, I was thinking that Level 1 on the 48V might be more than she wants and level 1 on the 36V would be a way to start slower. Hearing the comments, I may be overblowing that thought a bit...
Tonester said:Regarding the charger, I do remember reading about the Cycle Satiator (thx @amberwolf), but didn't know if there were other chargers that work the same way; seems the answer is NO. I likely won't get this expensive CS charger, so one more good reason to stick with 48V for both.
Tonester said:@Daytriker - You're thinking along the lines of what I was; don't get more motor than you need. Since I think both motors weigh about the same, we're just talking about battery weight which would be 4 or 5 lbs at the low end and around 8 at the higher end; I'm thinking not enough difference to justify going smaller and risking running out of juice someday. Let me know if my assumption on weight is incorrect.
Tonester said:@Waynemarlow - good info you provided on your wife's experience and your mileage/usage! Sounds like Level 2 or 3 is not going to be overwhelming for her and if it is, we still have Level 1.
Tonester said:@RTIII Good point on the throttle! I'm hoping to get the throttle version (8-pin) for my trike, but not hook it up until I think I need it. Plenty of people here regretting not waiting for the throttle, so I don't want to look back and kick myself. Does anyone know if you can simply leave the throttle disconnected on the throttle version?
Tonester said:Good to hear you feel the 48V won't scare her. True that the $ are not much different between the two and I'm leaning toward the 48V for that and all the other reasons. I'm gonna try to use the same mount, but it may be difficult since a dolphin or bottle battery may not work well on the trike; we'll see... Good point that any extra weight of the battery is mostly offset by the motor assist.
Tonester said:Again, thanks all for the great advice! One of these days, I'll learn how to do one of those fancy multi-quote replies like RT!
itchyfoot42 said:The 52V battery is a poor choice for the 15A version of the TDSZ2.
itchyfoot42 said:Assuming the max charge for each cell to be 4.2V and the performance cliff voltage to be 3.35 a 13 cell 48V battery will have a fully charged voltage of 56.6. Full charge on my 52V battery is 58.8, BUT my 15A TDSZ2 will not start until discharged to about 55.5. On one occasion I got a start at 56V, but haven't been able to replicate that. The killer is that while both start at 55-56V, low voltage (out of usable power) is 46.9V for the 52V battery while it is 43.55 for the 48V battery. The 48V battery can be drawn down 13.5 volts, while my 52V battery can only be drawn down 8.7 volts, ALMOST 30% LESS!
I'm not an EE, so may not understand the impact of these numbers correctly, but it looks like my early adoption based on the then tribal wisdom that all 48volt motors should work on 52V has really reduced my range by 30%. I'm also assuming that a fully charged 48V battery at 56.6V actually starts the 48V TDSZ2.
itchyfoot42 said:I think the torque sensor has a good bit of “slop” as just riding along with no discernable change of effort, I will get a difference of 200 watts on my meter.
itchyfoot42 said:I have the small XH-18 display/controller. Not sure if it actually has any “control” function other than to send the level setting to the controller in the motor. If I let it set inactive for 5 minutes it shuts off and will only reactivate with a battery switch recycle.
itchyfoot42 said:If range proves inadequate for my riding it appears to be less expensive to upgrade the motor than change batteries. As the 18A version “eye” is importing is only a software change I want to see how it survives, particularly the blue gear, pulling 18A and up to 1000 watts. My motor doesn't get hot so should survive, but the blue gear may not handle the inevitable abuse.
RTIII said:Yes, and you're leaving out a key factor in the voltage decision: the higher the voltage, the more efficient and also the smaller the wire diameter can be for equivalent losses to resistance. This is one of the reasons Tongsheng can bump the voltage, first from 36 to 48, and now to 52 with basically the exact same unit; the wire diameter requirement actually goes down, thus making room in the assembly. This means more power from less weight. The only real tradeoff here is the number of cells required to make a "stack" of the higher voltage because this is the key multiplier in battery bulk and weight. (At some point, there's yet another trade-off for safety. At around 50, it's still relatively safe. Get it up much over that, certainly before 100V and there's real risk to anyone who handles the battery, should they get unlucky and become a part of a circuit.)Tonester said:Mostly, I was thinking that Level 1 on the 48V might be more than she wants and level 1 on the 36V would be a way to start slower. Hearing the comments, I may be overblowing that thought a bit...
I can't say the Cycle Satiator is the only one like it, but it's certainly the only one I found after some hours of searching. If NOT going for the Satiator, then get one that has two "lower" settings, typically sold as "80%" and "90%". I recommend this because it'll give you some flexibility and better battery longevity. ... Somewhere here on ES, I published links to the data sheets for several of the cells and pointed out some of the differences, especially in charging requirements (but also discharge - more on that in a second). If you don't get a Satiator, second best is to be able to look up YOUR cell type's requirements and then flick the switch to the appropriate charge voltage of your "dumb charger." It's also good to know that for ALL batteries of which I'm aware, and the more discharged, the more important this is, that the charge start slowly for the first bit, then increase, and under all conditions the charge should be tapered off. With a "dumb" charger, simulate this by manually flicking those switches. For example, you're 40% depleted, so start at 80% and after 10 minutes or so, flick it to 90%, then later to full charge rate for however long you estimate, then flick the switch down again to 90, or even 80%. ... Your final charge voltage you want will depend on many things, but these batteries DO NOT like to be over-charged! Unlike a "wet cell" or "flooded" battery, they can't out-gas, so instead the chemistry just gets screwed up and they die an early death.
Yes, you can leave it disconnected OR connected. It won't do anything if it's off. You can ride normally and get assistance with the throttle hooked up but while NOT using the throttle... It's an either / and situation. So, hook it up and just ignore it until you want it!Tonester said:@RTIII Good point on the throttle! I'm hoping to get the throttle version (8-pin) for my trike, but not hook it up until I think I need it. Plenty of people here regretting not waiting for the throttle, so I don't want to look back and kick myself. Does anyone know if you can simply leave the throttle disconnected on the throttle version?
You can get creative on the mount! There's a thread here on ES devoted to home-made mounts, and while you may not want to make your own, it shows literally hundreds of different ways to mount batteries... For your typical Shark or Dolphin mounts, they can go on the top tube, seat tube OR down tube, OR on a front or rear mounted cargo rack! And, you don't necessarily have to modify the frame any. Take a look at my Legran's solution - no mods and mounted to the seat tube:Tonester said:Good to hear you feel the 48V won't scare her. True that the $ are not much different between the two and I'm leaning toward the 48V for that and all the other reasons. I'm gonna try to use the same mount, but it may be difficult since a dolphin or bottle battery may not work well on the trike; we'll see... Good point that any extra weight of the battery is mostly offset by the motor assist.
https://endless-sphere.com/forums/viewtopic.php?f=3&t=88943
Page 2 has a lot of photos of it, but I don't recall if somewhere I did a close-up. I used a simple bit of flat bar stock, 1/2" wide, 1/8" thick, bent it to transit down the seat tube and up the bottom tube some, and clamped it to the frame with simple hose clamps. Paint damage is avoided with just some black tape where the clamps go... On my San Rafael, I mounted the same battery mounting system to the rear cargo rack - photos aplenty here (and again Page 2 likely has what you want):
https://endless-sphere.com/forums/viewtopic.php?f=3&t=89956
eyebyesickle said:I'm thinking the loud motors may have to do with the initial gear install/greasing... Looking into that theory, because out of all the units I sold (not that many), so far we have 1 that is sounding loud...
