Hmm nope it did not fix it. It was already at 250.btslo said:cnrd said:btslo said:cnrd said:Hey I installed the custom firmware.
I got the firmware flashed and wires set up, but now there is no motor power at all.
The KT-LCD3 turns on and seems to work.
It is showing speed correctly but motor power is stuck at 0 and there is no help.
Make sure you configured everything on the LCD, especially max motor power. Mine was set to 0 and had the same issue.
Is it the one called "Motor power limit"?
My assumption was that having that set to 0 would mean that it would just use the amp limit * battery voltage as the max limit.
Yes.
I thought so too but that's not the case.It's set to 250W in the 0.20 version to avoid these problems.
However I looked in menu 9, it seems like both cadence and torque changes, however human power is stuck at 0. Could that be related?
