Interesting. What sort of cost for the parts and is it worth it?casainho said:Recently I upgraded my wifi ebike TSDZ2 to the most recent version by changing the main gear and pinion to be helical - the main advantage is to have a more silent TSDZ2:
Go and see by yourself the prices. You can find on Aliexpress that parts.mctubster said:Interesting. What sort of cost for the parts and is it worth it?casainho said:Recently I upgraded my wifi ebike TSDZ2 to the most recent version by changing the main gear and pinion to be helical - the main advantage is to have a more silent TSDZ2:
Aquakitty said:sidmodi said:Hello,
I have crossed 1500km with my TSDZ2 + OSF combination on a Trek FX 7.2 Hybrid (2015) and am absolutely loving it. I have, however, throughout the whole time, had one issue that I cannot seem to fix. Whenever I increase the human torque and start pedaling hard, I hear a 'clicking' sound coming from the right side of the bike. It seems like a metallic sound and only happens when I press hard on the right pedal. If I press hard for multiple cycles, the sound is regular and periodic. It almost feels like a creaking sound. I will try to get a video next time but in the meantime, does anyone have any ideas? I have the motor secured on both mounting points - bottom bracket and the additional mounting plate as well; it seems unlikely that the sound is being caused by the entire motor moving and pressing into the frame or something. I know that there is an offset on the stock crank that makes the left and right side asymmetrical. Could that be a possible source of problems? Any help would be appreciated!
Thank you,
Sid
Another idea, possibly bearings in your pedal. Very common for them to click when they blow. If your pedals feel too easy to turn it could be it.
To the corrosion person, that's what happens when you overheat a motor, the "white powder". That would also cause the power loss. Only solution is a new motor (you can buy just the motor which is cheaper).
cream said:tsdz2ebike.jpgAbout a month ago, I finished my first E-mtb build around TSDZ2 motor. I really like how this little motor feels, even with stock firmware. Installation was quite easy in my case, except the rear shifter cable which was originally routed on the BB so I had to reroute it. Other than that, the kit was a perfect ft.
I spent some time reading this thread and the other one with > 200 pages. I was going to try it anyway but after reading I was quite anctious to try it on my bike.
OSF firmware is the best thing that happened to this electric kit, I just had that smile after initial testing. I wish to say thanks to all the project developers.
Now, I'm using 0.19 firmware with KT-LCD3 and 13.5Ah 48volt Shark case downtube battery. The assisted power mixes better with human power, the motor seems quieter than before and the fact that you can customize so much just by using the display, it's just awesome. Not to mention the readout of important parameters like torque sensor ADC value, batt voltage, etc...embedded diagnosticsPlaning on upgrading the battery to a 52V model for a higher cadence across all levels of charging. I do have some experience fixing electronics so programming didn't take long and the good thing was that I had a Stlink V2 dongle lying around somewhere.
One thing that I noticed since I switched from stock firmware is that the assistance starts a bit slower, most of the time I need to half rotate the crank to get power. Also, when I stop the pedaling, the motor will keep going up to 1 second (depending on the assist level/cadence), in which time I can change gears without pedaling) I don't think it's only the innertia of the gearing system inside TSDZ2, it seems like the power keeps going for a short time after I stopped pedaling. Did anybody else encounter this?
I also did temperature sensor mod and some kind of thermal management by means of mounting silicone pads around the motor steel core. It's way better than stock pocket of air, I have around 15C degrees difference on the same road and same ambient temperature.
Did around 700km on mixed terrain. So far, no problems, but I've already ordered replacement parts. I like to have them around, just in case. I will soon have spare plastic gear and a metal one and a CSP 30-P from Stieber (should take more than stock Chinese 110Nm). I notice all replacement sprag clutch I found, don't have the groove for the o-ring like the stock one.
I did notice a quite large radial play of the chainring and the spider, when I did the install. It seems like too much clearance between sprag clutch inner race and the torque sensor shaft and not play in the bearing itself. The play was present since 0km. Maybe it has more play now, don't know for sure. Here's a video:
https://vimeo.com/355198161
Doohickey said:Hi all, first post here
I'm strongly considering this motor for my first ebike build. I'm confident with electronics tinkering and firmware flashing from other hobbies, so this one should be no problem. The base bike will be a Rockrider 540 from decathlon. (Photo of bottom bracket here)
Couple questions especially if there's someone with this bike:
* This bike has the shifter cables and hydraulic brake lines under the bottom bracket - is there enough clearance between the motor and the frame that they can stay there ? (Also: does the stock 42t chainring fit without hitting the chainstay, and how's the chainline?)
Some questions about the firmware:
* on the sw102 display, is it possible to get power and speed data out via bluetooth (either in realtime or after)?
* For possible future mods, does the mcu in the sw102 have unused pins that I can solder an additional sensor connection to (and modify the firmware to show it) ? I might want to add a current display for solar panel.
I own 2 of the 540S and I posted here notes about how to install: https://github.com/OpenSource-EBike-firmware/TSDZ2_wiki/wiki/How-to-install-TSDZ2-on-a-full-suspension-bicycle#Decatlhon_RockRider_540SDoohickey said:Hi all, first post here
Go and read the wiki, including the FAQ: https://github.com/OpenSource-EBike-firmware/TSDZ2_wiki/wikivolcamin said:Hello everyone! I just purchased my tsdz2 motor from aliexpress. I got the 36v 500w version without brake and thumb throtle, and now i regret not choosing the one with the thumb throttle, is it possible to add my own afterwards?
Thanks very much already
If I bought my TSDZ2 recently (within the last 2 months), it should already have the helical gear, is that correct?casainho said:Recently I upgraded my wifi ebike TSDZ2 to the most recent version by changing the main gear and pinion to be helical - the main advantage is to have a more silent TSDZ2:
I don't know. That motor is at least 1 year old.CatfishMan said:If I bought my TSDZ2 recently (within the last 2 months), it should already have the helical gear, is that correct?casainho said:Recently I upgraded my wifi ebike TSDZ2 to the most recent version by changing the main gear and pinion to be helical - the main advantage is to have a more silent TSDZ2:
Great thanks for confirming. Have ordered the two parts. Time for my first teardown almost 2000kmsflufferty said:mctubster said:Interesting. What sort of cost for the parts and is it worth it?
I've just done the same and YES it's worth it
I went from a low growling dog-machine to an electrical sounding bicycle engine.
thineight said:In case of spray clutch replacement I might consider a switching from straight to helical gears: in this case it is necessary to buy both big gear and reduction gear, correct? Is the second one available on pswpower?
Thanks, did anybody tested side by side the two gears and confirm that the helicoidal is quieter?flufferty said:Yes, the little axle/gear mesh against the big sprag clutch gear. Can't find it on pswpower, but it's available at aliexpress, https://www.aliexpress.com/item/33011901273.html
I did, mine ebike always had helical and my wife always had no helical -- I could clearly listen the difference, no helical does more noise and is then less "elegant" when we are riding near the other no ebike MTB riders. Silence is important when we are on the quiet mountains. No one would ever accept to ride near a bicycle with a gas motor (although there are also chinese KITs of gas motors for bicycles), doing high noise and fumes, electric has a very good advantage herethineight said:Thanks, did anybody tested side by side the two gears and confirm that the helicoidal is quieter?flufferty said:Yes, the little axle/gear mesh against the big sprag clutch gear. Can't find it on pswpower, but it's available at aliexpress, https://www.aliexpress.com/item/33011901273.html
