Hi all.
I've just got a new TSDZ2B motor and having read about fitting 2 bearings had them ordered - however, after eight kilometers the left bearing started making a noise, so I had to order a third bearing... and circlips because the ones on the machine are as bad as the bearings. I managed with the point of a scalpel to get into the bearing and it had only a smear (being generous) of grease in it, packing it with some more seemed to make it behave better, but I decided not to continue using it.
Now my problem - and dilemma :
The problem has migrated to the main gear assembly after maybe 50km of use. You may have heard it's been sort of hot in France and yesterday was the first with a cool enough morning to do further testing, it got warmer and then the sound of another bearing in trouble, more when pushing on the left side, but also pushing down on the right - louder and of a different pitch than the small left side one. Anyway it's the only one left to go wrong.
Initially I thought it could be a pedal, so I spent part of the afternoon doing some (overdue) maintenance. The problem is still there.
I suspect that the fault is the same as in the small bearing - not properly packed with grease, and possibly the wrong grease. I had had brief moment of the same noise which seemed to have cleared itself and the circumstances were similar, that is high temperature (in the 30's).
My question is this : is it possible to disassemble the main gear and re-pack the bearing with grease or am I going to have to send it back and start again ? Which will mean that I won't get away this year (I use it for cycle touring - I no longer have strength to get a loaded bike up the hills)
I notice that the walls of the bearing look like mica, but are probably rather brittle plastic that doesn't fit very well, so I could possibly inject grease into the bearing if disassembly is not too difficult.
Your advice please - I bought it through Aliexpress, which was probably a mistake...
