Ordered that, I hope deliver don't take ages.
I am not sure but I think it is already possible.I think readme quite clear. I'm still waiting for motor and j-link. Motor will arrive soon but j-link and cable for that might take long.
Is it possible to make this software also for 860C display?
This fork is based on the TSDZ2-v0.20beta1 adapted for Tongsheng protocol displays, like stock VLCD5, VLCD6, XH18 or other displays with the same protocol and 6-pin Tonsheng connector, SW102, DZ41, 850C or 860C for TSDZ2. With these last displays, the visualization of data and errors must be checked..
endless-sphere.com
I use 860C display with TSDZ2 and TSDZB. It works fine. But it have to flashed also, not only motor. mbrusa allways makes different versions for displays.I am not sure but I think it is already possible.
In fact for the code managing the display, I tried to copy exactly what mbrusa did in his version of OSF.
In his readme section, he says;
To be sure that 860C could be used, best would be to ask the question on the OSF forum for TSDZ2.
TSDZ2 OSF for all displays, VLCD5-VLCD6-XH18, LCD3, 860C-850C-SW102.
Before I retired used PEEK all the time. It is a high-performance thermoplastic with excellent environmental resistance, dimensional stability, and mechanical strength compared to Nylon. It goes thro' all the grades to those containing glass or carbon fibre. I would prefer to use PEEK instead of...endless-sphere.com
I am afraid this becomes quite confusing.I use 860C display with TSDZ2 and TSDZB. It works fine. But it have to flashed also, not only motor. mbrusa allways makes different versions for displays.
Release Firmware open source TSDZ2-v20.1C.5-860C · emmebrusa/TSDZ2-Smart-EBike-860C
The TSDZ2-v20.1C.5-860C version is the confirmation of TSDZ2-v20.1C.5-beta-1-860C. No changes. The manuals are not yet updated. 850C Displays are no longer recommended as changes in hardware often ...github.com
By the way I ordered TSDZ8 with 860C display. So I think stock firmware works with it. I cannot order TSDZ2 or TSDZB with 860C display, only choice is VLCD5.
Link to PSWPower TSDZ8.
second hand TSDZ8 tongsheng Mid Drive Motor Kit 750W Engine with torque sensor for ebike ------UK warehouse
second hand TSDZ8 tongsheng Mid Drive Motor Kit 750W Engine with torque sensor for ebike ------UK warehousewww.pswpower.com
OSF (at least the version that I reused) has currently more that 100 parameters that can be choosen by the user.Which is why the java configurator is such a handy tool.
I'm just curious about this, but did you consider bbs-fw at all? It does already support tsdz2, but has a downsideI am afraid this becomes quite confusing.
I expect (but I am perhaps wrong) that there are several versions of OSF.
Some requires to flash also the display. It is then possible to take profit of the display possibilities (e.g. to get more data on the same screen).
There is one version that does not require to flash the display. It is this one that I adapted for the TSDZ8.
The advantage is that it does not require to change the display.
The drawback is that it is not so user friendly (and perhaps does not offer to change as many motor parameters from the display)
I did not know this project but if I understand it rigth, it does not support the torque sensor of the TSDZ2. Futhermore, it can't be used for TSDZ8 because TSDZ8 uses another microprocessor.I'm just curious about this, but did you consider bbs-fw at all? It does already support tsdz2, but has a downside
of supporting only bafang uart displays. Upside(imo.) is it does allow changing settings written into the flash, and
can be configured to be usable w/o any display at all.
There is code for the torque sensor in bbs-fw for TSDZ2, but these TSDZs are totally unknown to me,I did not know this project but if I understand it rigth, it does not support the torque sensor of the TSDZ2.
Yes, that's why i asked if you did consider porting it to TSDZ8, as it is already "structured" toFuthermore, it can't be used for TSDZ8 because TSDZ8 uses another microprocessor.
Didn't ask you a thing. If i knew as much as you i'd just stfu now.What use would a Tongshen be with ... ugh... bafang firmware without torque sensor support... just buy a .... ugh... bafang... then.
I feel this walking sewage leak here got out of bed with the wrong foot today.Didn't ask you a thing. If i knew as much as you i'd just stfu now.
So you splatter from the wrong end of evolution should perhaps 'stfu', like the malfunctioning porto-potty in human form tells others when he thinks they have nothing to contribute?There is code for the torque sensor in bbs-fw for TSDZ2, but these TSDZs are totally unknown to me,
so got no experience with it.
Yes it is and no issues.Hi,
Do you know if the TSDZ8 is compatible with a 52v battery ? some issues with 52v ?
I expect that my OSF version for TSDZ8 could be adapted for the TSDZ2 V2. Still it would require several minor changes mainly because TSDZ2 motor has 8 poles instead of 4 poles for TSDZ8.@mstrens
Question regarding your OSF version:
As the ENERdan TSDZ2 also has the V2 controller, do you think your firmware works on this motor too?
I have a TSDZ2 with V2 and a TSDZ8 here for testing, but I wanted to try it first on the TSDZ2. My TSDZ8 bike is farely new I dont want to risk damaging it.
This is good news. I have received Motor but I'm still waiting J-link. It should arrive next week but that is only estimate.I expect that my OSF version for TSDZ8 could be adapted for the TSDZ2 V2. Still it would require several minor changes mainly because TSDZ2 motor has 8 poles instead of 4 poles for TSDZ8.
At this stage, I do not plan to adapt my version for TSDZ2 V2.
My priority is that it works for TSDZ8 with a VLCD5 display (or similar).
Afterwards, I plan to make a version for TSDZ8 with a 860C display (this allows the user do change all config parameters from the display without need for a configurator/reflash).
I am still waiting that someone accept to test my version.
In the meantime, I am fine tuning my version (trying to implement some more calibrations and optimizations).
Thus I think I don’t like it. I’ve read that two first assist levels assists too much.
