Mid Drive verses Hub, depending on which models we chose, either could be heavier than the other. I think we have to define the goals first, then build to suit (at least in theory).
The next bike I build will begin with 100 lbs. of batteries cos it is designed for road speeds. I don’t have a big need for Enduro; I live in the urban area and I think about migrating out of the margins and into traffic full-fledged. However – the Enduro study is really a close cousin to what I want next, so it’s enjoyable to compare.
If we’re talking “
bicycle” off-road, it’s got to be
lightweight. My bike can carry 30 batteries before it begins to shirk, and I can still pour another 12-18 on top before the handling becomes challenging; over that amount and it is problematic. That’s where the trailer comes in cos it can easily accept another 30 batteries. :wink:
When the bike it loaded up, I try to keep most of the weight over the triangle for better handling. The rear suspension gets squirrely with any weight, however there’s a wide band of acceptance before it becomes unmanageable.
If we’re going with a
motocycle/motocross bike, then provision for a frame that can handle at a minimum 250cc ICE cos these bikes begin with an unloaded weight of 450 lbs. and that’s right where we want to be for motors and batteries. If we use hubs, then the whole engine cavity is available to accept a modular battery pack. However a mid-drive eats up a lot of good real estate, but then your wheels are lighter and more responsive. How to optimize? It depends again upon the goals: Do we want distance, long mountain climbing, racer, what’s it gonna be?
The way that I look at a bike frame is “
how much can I pack on it?” – and the 250cc model says I can place 200-300 lbs. before I’d need a trailer. Now the thing about motorbikes is that we have to answer the question: “
Are we going to pedal?” If we do, two options are ‘pedal with gears’, or ‘pedal to generator’. The argument against pedaling is that we’re only adding about 200 watts/hour and it’s a lot of complexity for little gain. On a bicycle it makes sense, but on a motorbike is does not. That’s weight we can save. When I was going cross-country, the weight of the batteries began to work against me; I could throw more batteries onto system, but in the city it was killing performance. Here’s an example:
This bike, P1 – loaded up with 18 batteries that weigh about 24 lbs. can get me from Redmond to Seattle and back on one charge, about 46 miles round trip, and takes 70 minutes each way. The route is a combination of city streets and bike paths through dense urban traffic. Compare that to having 78 batteries for the road trip, and I was constrained to about 170 miles distance (I don’t know the limit for 2011 cos I never ran out of power). Doing the math:
- 46/18 = 2.55 miles/battery when commuting.
170/78 = 2.18 miles/battery when touring.
When I commute, I’m only carrying the clothes on my back when I change out of riding gear, and a laptop, maybe 12 lbs. Granted – it’s likely I’m going close to WOT on many parts of the journey.
When touring, it was well over 50 lbs. of gear: tools, parts, multiple changes of clothes, food and water, my charger, plus the weight of the trailer (not counted) – and resistance. I am extremely miserly when touring, particularly with headwind, and I think nothing of dropping my speed and pedaling more to help the motor. Still, the weight of the batteries begins to be part of the problem when you get over 50 lbs.
When we consider alternatives such as motorbikes, we have to accept the evil of battery weight, and overcompensate by having powerful motors. Two works better than one on a hill! If I lived in Flatland USA, mid drive or single hub motor would be fine. I live in Seattle, and there are two mountain ranges between me and my family, so I’m going to with 2WD for any weather and all terrain (caveat that it’s primary goal is for pavement). I already know and accept the next bike will go on average 55 mph and likely will consume 3 to 4X the amount of power I was using to go 30 mph, plus I’m not pedaling. Got to design a bike to suit the needs of the goals. For that, my money is on a frame that can hold a 250cc ICE at the very least, and have an unladed distance of 150 miles minimum whilst doing 55 mph at STP – the
Minimum Bar for success.
Anyways – that’s a part of the dream for the electric ride. One day at time.
Do you have a build thread started? We could go there and ponder options 8)
Cheers,
KF
