Alan B
📗 Minor legend
16x4 is very close to the Cromotor's 18x4, and the MXUS 3000 is 16x4 as I recall.
The MXUS 3000W V2 is indeed a 16X4T wind.Alan B said:16x4 is very close to the Cromotor's 18x4, and the MXUS 3000 is 16x4 as I recall.
Alan B said:Another way to look at it is that 33% more FETs will be needed. However adding FETs becomes less effective, so more FETs will be needed by another factor as current division is not equal. So 50% or more FETs must be added. I've had many 24 FET failures on the 18x4 turn motor, so perhaps a 36 FET would be recommended for 3 turns. Cranking up the current on the same controller won't get parity, that could always have been done on the higher turn motor, and won't result in the same reliability or safety margins. Lower inductance and resistance require better controller design which may mean moving to much more expensive controllers, preferably with actual phase current measurement and control.
Also watch the eRPM and motor losses if RPM increases are planned, lower pole count motors are designed for efficiency at higher RPM.
liveforphysics said:Alternatively, you could just embrace the improved FET technology available today.
Remember, copper and iron aren't likely to make any magical substantial improvements over time. Silicon power switching density gets improved by someone every few months.
http://www.ti.com/product/csd19506kcs
teslanv said:liveforphysics said:Alternatively, you could just embrace the improved FET technology available today.
So Would this be as easy as swapping out the FET's in a standard Xie Chang controller to a newer more current capable model of MOSFET, or would it require a redesign of the controller to accommodate the newer FETs?
I think the Rdson vs the voltage are the most important specs. If you have a mostfet with 2x the rdson its going to produce more heat might not be 2x more heat but its more so the rdson is very important you still need to look at all specs but I don't ever bother with FETs with high rdson because they have no hope feeding the current the lower rdson FETs do.zombiess said:teslanv said:liveforphysics said:Alternatively, you could just embrace the improved FET technology available today.
The die are more capable than the legs and bond wires which feed many modern power MOSFETs. Losses are more involved than just conduction which are the losses often referred to on this site when talking about RDSon.
The package and its ability to shed heat are a limit on many MOSFETs. Data sheet specs need to be taken in the context of the real world.
Alan B said:The Xie Chang controllers probably won't benefit all that much from the better FETs since they don't drive the FETs properly. There will be some benefit, but not the full improvement. New controllers with proper design are required.
It will be like that for a long long time my friend. Priced out the OEM leaf inverter today and its 7100cdn!John in CR said:$20 more for a controller is fine. Where I have the problem is when the little aluminum box of electronic bits cost more than the motor it drives.
Would some 3-axis graphs like those on the Launchpoint page help?Miles said:Something that we really need to give attention to is the relationship between:
DC voltage
Direct current
Peak to peak voltage
Peak voltage
RMS voltage
Peak current
RMS current
Block commutation
Sine commutation
speed
torque
Kv
Kt
I was only thinking that we need to be aware of the differences, conversion factors etc.gogo said:Would some 3-axis graphs like those on the Launchpoint page help?
http://www.launchpnt.com/portfolio/transportation/electric-vehicle-propulsion/
Alan B said:I find the Cromotor produces plenty of power at 18x4 and 120 amps phase current (80 amps battery), but with a sine wave controller at 18S it tops out at about 32mph with 17" moped tires a little over 23" diameter, which is excellent. Field Weakening can push it to much higher speeds but I haven't bothered. It can be pushed much harder.
justin_le said:John in CR said:$20 more for a controller is fine. Where I have the problem is when the little aluminum box of electronic bits cost more than the motor it drives.
Just putting it in perspective, in most industries the price of the motor controller is roughly comparable to the price of the motor it drives. Even in the uber cheap world of RC motors and controllers this holds true more or less, so I don't see why you'd expect ebikes to be that different. I once thought it seemed pretty crazy too, but the actual expenses involved in making a 3 phase controller are comparable to making the motor that it drives. There's no moore's law for mosfets, heavy copper PCBs, electrolytic capacitors, etc. Microprocessors have gotten much cheaper and more powerful, but that's only a small part of the BOM cost of a good motor controller.
Combine the above with the fact that controllers do some sort of 'from zero RPM' current limiting and you end up with an even shorter blip of torque.madin88 said:i believe the 8x8 only will produce twice the torque at stall or at very very low rpm and than torque drops very fast because it max out at only half the RPM compared to a 16x4. this has to do with back EMF (the voltage the motor pruduces if you would spin it "by hand" at given RPM), phase resistance -> therefore voltage drop in windings.
or with other words the 8x8 only draws max power for a very short time because it reaches much faster top speed or max RPM.
teslanv said:Coming back to the Myth a little here:
Is it fair to say that for a given motor design (And negating any controller inefficiencies), if you were to compare a 16X4-Turn motor to a 8X8-turn motor, could you accurately say that:
For a given battery voltage at 100% Throttle, the 16X4-Turn motor will spin exactly twice as fast as the 8X8-Turn motor and for a given battery and phase current profile (amperage) the 8X8-turn motor will produce twice the torque as the 16X4-Turn motor.
Or to say this statement a different way:
It takes twice as much voltage for an 8X8-turn motor to spin at the same RPM as a 16X4-turn motor, and it takes twice as much current for the 16X4-turn motor to produce the same torque as the 8X8-turn motor.
I am not trying to propagate any more myth here, just trying to confirm that what I understand about the relationship between a motor's winding, and Speed and torque are accurate.
