999zip999
Super legend
When it works can you draw a diagram for hooking up the C.A. plug.
999zip999 said:When it works can you draw a diagram for hooking up the C.A. plug.
999zip999 said:One those Ebike tester says it will tell you the phase and maybe Or halls . It in print.
Hummina Shadeeba said:If u want to FaceTime tomorrow or late tonight pacifi standard time I could try. I’ve got many going in the past using Vesc.
610-416-2650
999zip999 said:Well well good luck as I have to go down and try to get my Crystatlye 72v 50amp controller.bI tried till I got the the old Lyen 18fet and both didn't work with spare edge 1,500 motor it would go be after 20sec it would die both controllers same problem bso I changed motors and the Lyen works. So next I have e break down to test it. But it's so hard taking apart a working setup to test it. I have to just go ride. 4mm to 5.5mm phase connectors. And Wow from 43mph to 46mph.
My bike needs bling. ( Gold ) plated bullet's
Funny, I was just contemplating the opposite.E-HP said:... The nice weather riding days are coming to an end ....
torker said:I am wanting to go to a 52v battery on one of my old 9c dd hubs. And a bit more amps.
Do you think one of the controllers you are using will work . I also would like to have a display maybe.
thundercamel said:That looks like the same controller that APL uses, but his thread linked here which is a little cheaper.
LewTwo said:Funny, I was just contemplating the opposite.E-HP said:... The nice weather riding days are coming to an end ....
The monsoons are ending and cooler weather makes for a more pleasant ride![]()
E-HP said:torker said:I am wanting to go to a 52v battery on one of my old 9c dd hubs. And a bit more amps.
The temp one I'm using now should do 52V, but it won't have a display; but the one I'm about to install only works on 60V or 72V, and has a jumper to set the voltage.
https://www.amazon.com/gp/product/B07MS143GY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Is that smooth because you're back to sine wave or because it has more power? (or something else)E-HP said:I can't get over how smooth it makes the motor run; hills just feel effortless.
thundercamel said:Is that smooth because you're back to sine wave or because it has more power? (or something else)E-HP said:I can't get over how smooth it makes the motor run; hills just feel effortless.
electric_nz said:Great thread! I had seen these and wondered if they were any good. How do you select between 60-72V? Does it have a adjustable low voltage cutoff?
I have a 22S battery (88.2v fully charged) and was hoping it might handle that, any documentation with it?
There is also a 96V version which looks promising but if it has a non adjustable low voltage cutoff then it won’t be much use.
