d8veh said:speedict said:my question is, do you also need twist throttle input ? if you use PAS only, may be "PAS to Throttle" mode can help ..
by enable "cadence matching" + "throttle range setup" e.g. you can instruct speedict ebike to start power when your cadence > 10 rpm and set appropriate motor start power, i think it may help !!!
by the way we have plan to design customize power band e.g. you can design your power band by drawing the curve on your android device
danny
I presently use a potentiometer as a cruise control instead of a throttle. It's activated by a switch and I turn the knob to make adjustments to my cruising speed. What I would like is that it's activated by pedalling and stops when I stop pedalling. If the throttle only gave a signal when pedalling, this would be the same as what I want because I can substitute my potentiometer for the throttle. In some European countries it's not allowed to have a throttle that can work when not pedalling.
interesting, if i understand correctly, you want and you can use speedict ebike "road legal 2 mode" connect both your potentiometer and pas and owning to the regulation, when you stop pedaling it stop, when you want it be activated your pas cadence has to be detected by speedict ebike ... right ? tell me more see if we can help ?
