You might've missed the extra support bearing mentioned in the OP. Why do you think I picked a bottom bracket with extra space on the drive side? Miles did point out the eccentricity issue.Chalo said:Miles is on the right track with his support bearing coupled to the freewheel body.
Watch and learn. Panurge has already discussed this issue. While I wouldn't recommend doing this to someone without basic metalworking skills, I'm confident what I've done will work.Chalo said:Trying to install a splined crank on an incompatible spindle will only result in the destruction of the crank arms.
Chalo said:The only freewheel whose bearing is designed to spin with a load on it is the White Industries ENO, and its single bearing is not adequate by itself. (Conventional freewheels have two bearings, which are inadequate for other reasons.)
Of the 3 Crossfire units I have purchased, all have had detectible but neglibable lateral freeplay. Much tighter than Shimano, Dicta and Claws units that I have also purchased and tested.Chalo said:I sell lots of ACS Crossfire freewheels, and they crap out about as often as the ACS Claws freewheels I used to sell before the new model became available. They still have palpable free play in the bearings.
Because the lateral freeplay is neglible in the 3 Crossfire units that I have recieved, there is less ability for angular misalignment to cause the flanged lip of the freewheel outer to contact the outer radius of the freewheel lockring. Therefore the amount of angular freeplay is inadequate to allow potential frictional contact to cause the lockring to unscrew. The same can't be said of other cheapy freewheels which I had ongoing lockring unscrewing problems until I started using a dab of loctite on the lockring threads which completely sorted the unscrewing problem. No need for welding.Chalo said:When you overrun them with chain tension on them (as all these no-pedal crank drive kits do), they do the same thing that a hub would do if you ran it sloppy loose-- they digest their bearings-- which are not as nice as those in a hub, either. Generic single freewheels of the traditional Shimano/Dicta/ACS Claws type tend to unscrew their adjustable cones and fall to pieces when used this way.
Not true. Of the Crossfires I have recieved, all have had a small stack of three bearing preload spacer washers clamped under the lockring. Through experimentation I discovered that if the thinnest of the three is removed, the bearing preload becomes tightened up to the point where lateral play is completely undetectable. In my case though I decided the added frictional drag of this modification was not quite worth the tradeoff as I was not having run-out and/or lockring unscrewing issues with the standard preload.Chalo said:I haven't sussed out a Crossfire unit closely enough to judge whether it would be subject to the same kind of self-disassembling failure. But it certainly has not been designed to have the free play adjusted out of it, and thus it's clear that it shouldn't be spun under load as a routine practice.
I regularly desire and appreciate riding my mid-drive e-bikes without pedal assist (particularly when I'm tired after work). Freewheel cranks are a necessity to run a simple mid-drive setup under these conditions.Chalo said:I really don't understand why y'all can't just get your motor and pedal RPMs reconciled, and then simply pedal like a regular person with functional legs. It doesn't seem like a far-fetched thing to do, and then you could avoid all the crappy freewheel/ridiculous wide BB/terrible chainline nonsense that an overrunning crank brings with it.
boostjuice said:I regularly desire and appreciate riding my mid-drive e-bikes without pedal assist (particularly when I'm tired after work). Freewheel cranks are a necessity to run a simple mid-drive setup under these conditions.
Why don't you read the first sentence of the first post.Chalo said:A hub motor is simpler, wholly adequate for a workday commute
You first need to understand that there are different people with different needs to yours. Once you become comfortable with that everything else will make sense.Chalo said:I really don't understand why y'all can't just get your motor and pedal RPMs reconciled
Chalo said:boostjuice said:I regularly desire and appreciate riding my mid-drive e-bikes without pedal assist (particularly when I'm tired after work). Freewheel cranks are a necessity to run a simple mid-drive setup under these conditions.
I suggest that a mid-drive assist ceases to be simple when it acquires an overrunning crank. That does seem to be where many of the problems and troubleshooting come into play.
Chalo said:A hub motor is simpler, wholly adequate for a workday commute, and does not require you to pedal. It's an elegant solution to the problem you perceive. And a normal fixed chainring crank is an elegant solution to the problems with many mid-drive kits.
boostjuice said:I have a mid-drive rather than a hub motor on my Yuba Mundo for several reasons. Firstly for strength, durability and reliability reasons I wanted a 48 spoke rear wheel
with the tensile springiness of 14G spokes rather than 36x 12/13G spokes that seems to be the required flange drilling standard for big Chinese hub motors that would be needed to push a heavy bike like this around at any reasonable performance.
Front hub motors are a stupid approach on most bikes (IMHO) but a complete impractability on a rear-heavy cargo bike, so that ruled them out completely in this application.
As for the freewheeling cranks.... Every time I ride my Yuba Mundo there are occasions where I want to hold my body/legs rigid whilst cornering or able to focus my body's movement to maneuvre the bike's heavy wieght around - all whilst under power. Overrunning chainrings are a godsend necessity in allowing me to do this.
Billions of people survived without bicycles either. Yet someone did invent one. Correlation doesn't imply causation!Chalo said:boostjuice said:As for the freewheeling cranks.... Every time I ride my Yuba Mundo there are occasions where I want to hold my body/legs rigid whilst cornering or able to focus my body's movement to maneuvre the bike's heavy wieght around - all whilst under power. Overrunning chainrings are a godsend necessity in allowing me to do this.
Billions of bicyclists all over the world have suffered greatly by not being able to apply power while they coast. Good thing there are unreliable overrunning cranks that interfere with chainline and pedaling biomechanics all the rest of the time now, so you can avoid such needless torment.
Moving the bearings outside the shell created more room for a larger spindle inside, so external bearing bottom bracket systems can have both larger spindles and bearings than their traditional counterparts.
Spindle diameters could suddenly go up to 24mm, which made them stronger and stiffer than ever before. This was a MAJOR improvement, and created a much stiffer crankset/bottom bracket set-up, which is being widely used today. Almost every manufacturer has brought their own brand of external bearing bottom bracket systems to the market; popular models include Shimano Hollowtech II, Race Face X-type, FSA MegaEXO, and Truvativ/SRAM’s Giga X Pipe (GXP).
spinningmagnets said:http://www.bikerumor.com/2010/02/17/bottom-bracket-tech-breakdown/
spinningmagnets said:I know this link is from the freewheeling crank resources thread, but having it here too can help identify strong and viable options.
Thanks to wildharemtbkr for the link. http://durgendesigns.com/ddfwadapters.htm
durgendesigns.com has a $35 adapter that makes a non-freewheeling crankarm accept a FW, intended for bolting onto beefy trials cranks. I do not know the central hole ID, I assume its for a well-known beefy BB-shaft.
