skyungjae
I think another resource we should be looking into is what the EGO kit uses. From pictures, I can tell they use ECHO trial cranks, but the big mystery is the bottom bracket.
In their promo video it looks like rider's foot slips off the pedal OR the spindle breaking on the big dropskyungjae said:I think another resource we should be looking into is what the EGO kit uses. From pictures, I can tell they use ECHO trial cranks, but the big mystery is the bottom bracket.
wildharemtbkr said:Haha good point! I like the outboard bearing, but I think the bearing and the freewheel would be trying to share the same space. I have a pair of Isis trials cranks I want to put on my norco, but I think I'll go with the gigapipe bb. I'll post up some pics when I get it going.
...Offset Bottom Bracket Cartridge 153 mm fitted with hybrid ceramic bearings that helps increase drivetrain efficiency...
spinningmagnets said:I don't know what BB cartridge AFT uses, but it has to at least a little better than the "lowest bidder" cartridge that the GNG comes with...
http://www.af-tech.com.au/Products_Ebikes.html
$133 Standalone price
19-22mm bottom brackets come in both inboard and outboard bearing varieties
Well, there were several failures reported.... You shouldn't expect to be able to use a single CSK unit without further bearing support.spinningmagnets said:On a completely different path: ES member elation was selling these from Australia for $250 using a CSK-PP clutch-bearing. Since it was the #35 size, I seem to remember it can take an adequate level of power?
Miles said:Well, there were several failures reported.... You shouldn't expect to be able to use a single CSK unit without further bearing support.spinningmagnets said:On a completely different path: ES member elation was selling these from Australia for $250 using a CSK-PP clutch-bearing. Since it was the #35 size, I seem to remember it can take an adequate level of power?
Early failures are usually the result of design and specification by the clueless....skyungjae said:I think failures are going to be the end result without proper maintenance and replacement regardless of going with a clutch bearing or freewheel.
Miles said:Early failures are usually the result of design and specification by the clueless....skyungjae said:I think failures are going to be the end result without proper maintenance and replacement regardless of going with a clutch bearing or freewheel.
gestalt said:couldn't you go extra long on the BB to provide space for the support bearing and the motor mounting sheets? your crank arms would be farther apart but that's usually the way we like to run them anyways. then you do have to worry about chain line issues like I am having with my gng that only allows me to use my top five gears. I plan on spacing out the chain ring closer to the center with longer bolts and stacks of washers.
