3DTOPO
- Joined
- Apr 11, 2018
- Messages
- 499
Chalo said:Whatever you say.
:lol: :lol: :lol:
Man talk about some straight propaganda from the innertube sector. Jeeez
So obviously staged.
3DTOPO said:Chalo said:Whatever you say.
:lol: :lol: :lol:
Chalo said:I've seen worse in my own bike shop, so I doubt it.
3DTOPO said:It's like showing the worse possible car wreck in history and proclaim that is why no one should drive.
First time I made a little mess, though, mostly on cardboard which I just threw away along with some rubber gloves. Hardly a big deal for years of trouble free miles.
AZeBikeGuy said:OTOH I'm not going to get all dogmatic about it - do what works for you
I'm not telling you what works for you3DTOPO said:..But I'm going to have an issue when someone tries to tell me that I don't know what works for me regarding something proven to work for me.
AZeBikeGuy said:I'm not telling you what works for you3DTOPO said:..But I'm going to have an issue when someone tries to tell me that I don't know what works for me regarding something proven to work for me.
SolarBeaver said:Kinda regret bringing this topic in
markz said:Some people love tubeless and will fight to the end on their mound because it worked for them, but it doesnt work for others.
markz said:Changing an inner tube is so quick and easy. Bring along a patch kit or a spare tube. Takes no time at all.
markz said:Hate to be stranded and have to call someone to pick me up with tubeless.
SolarBeaver said:TuBliss doesn't use any sealant, it's just regular air, isn't it a perfect solution then? And as far as I can understand you can run 0 psi on the outer "tube", and pitching an inner tube is not easy at all. Even if you do, you can probably have a regular tube with you in case the worst thing happens.
The main benefit is obv to run super low PSI though.
I don't know Chalo, looking at this picture, one could, (at least theoretically) conclude that some guys just get so excited about bike/ebikes that they make a mess on themselves. :lol:Chalo said:3DTOPO said:Chalo said:After you get your bike home and mop off all the corruption
You're delirious. That is all I have to say to you on the subject and done trying to reason with you.
Whatever you say.
Rix said:SolarBeaver said:TuBliss doesn't use any sealant, it's just regular air, isn't it a perfect solution then? And as far as I can understand you can run 0 psi on the outer "tube", and pitching an inner tube is not easy at all. Even if you do, you can probably have a regular tube with you in case the worst thing happens.
You bring up a great point, there are more than one tubeless option out there, and some tubeless options are better than others.
SolarBeaver said:Hey, do any of you guys run 21/16 combo? I think with the linkage it should work just fine, and less spinning mass on the rear, also you can always switch to 19/16 with the stock front if you want more agility for some more demanding singletracks (same trick for 21/18'', but unfortunately you can't run Shinko 525 cheater and slightly more mass, but OTOH you can use TuBliss), and use the bigger wheel for more enduro-style riding.
It will probably look kinda funny though, so not sure if I I'm in
P.S.Having some second thoughts after ordering 21/18
thanks a lot m8!ggHawk said:SolarBeaver said:Hey, do any of you guys run 21/16 combo? I think with the linkage it should work just fine, and less spinning mass on the rear, also you can always switch to 19/16 with the stock front if you want more agility for some more demanding singletracks (same trick for 21/18'', but unfortunately you can't run Shinko 525 cheater and slightly more mass, but OTOH you can use TuBliss), and use the bigger wheel for more enduro-style riding.
You may have seen my post about my setup (10/6/20). I've been running 16/19 since a month or so before that. I still love the Shinko 525 cheater, and the geometry is fine. I also love being slightly lower, cause I have short legs.
I almost tried tubeless, but decided to stay with tubes and see how it went. I run 10 psi. In over a year, I've never had any type of flat. The beefier tires I use help a lot, and I only weigh 140, but another big factor is where/how you ride. Some places are just flat prone.
The main thing I wanted to note, in case you don't know - the 525 cheater is too wide for the standard swingarm, so it must be shaved (unless they have a new size that wasn't available a year ago... I'll find out when I buy a new one this Spring). Shaving was pretty easy, but makes a mess if you do it the way I did (with a table saw). I showed pics of it in my 10/6 post here:
https://www.endless-sphere.com/forums/viewtopic.php?f=10&t=89902&p=1588522&hilit=shinko+525+cheater#p1588522
