Normally the BMS doesn't monitor capacity directly and limit usage based on that, it only monitors the individual cell groups and limits based on their voltages. If yours does, perhaps you can post the info that shows this, and the model / brand of BMS, so we can see if there is a setup software for it that can alter it's settings.The original BMS of the battery is not capable of correctly managing the increase in capacity. Seeing that I cannot take advantage of the original BMS of the battery,
coulometer? Whats with this word and usage? Why all of the sudden peeps starting to use a coulometer instead of a wattmeter?If you don't connect the signal wires from the battery, the bike will still run, it just won't go into Eco mode when the pack gets low or hot.
Their BMS was custom made and I am not aware of any way to reprogram it. I have seen people modify the shunts on the BMS to allow higher current. If you did this mod with the right resistors, you could recalibrate the coulometer to match the new capacity of your cells and the SOC meter would be close to accurate and the low battery safety features should work.
Looks like the motor will be the skid plate and carbon fiber for a dirt bike frame sounds kinda weak.Will make a good road bike though.The new Solar (a well established e scooter brand) Eclipse may dethrone the Sur-ron.
Carbon fiber frame, more AH in the battery, uprated suspension and brakes, regen braking, higher max and continuous watt rating...
Cool. Maybe I can get a good deal on a surron from the 14 year olds who get these as Christmas gifts this year.The new Solar (a well established e scooter brand) Eclipse may dethrone the Sur-ron.
Can't help myself but loving this e-motorcycle! Few little upgrades here and there and it's perfect.The new Solar (a well established e scooter brand) Eclipse may dethrone the Sur-ron.
sur ron
A 60% scale motorcycle is great if you're a 60% scale human. I'm a 125% scale human and Sur-ron looks like a little kid's toy.Can't help myself but loving this e-motorcycle! Few little upgrades here and there and it's perfect.![]()
Ah, they also make a little kid's motocross bike along with the pit bike. Cute.Thats why Sur Ron, besides the Light Bee, also make the Ultra Bee and the Storm Bee. The latter is more suitable for your size "human/Bigfoot" types![]()
Now that is an inspirational vehicle. No fun at all to ride as regular transportation, I'm guessing, but inspirational nonetheless. When I rode motorcycles, they were mostly 1100cc standards.
You need to build an EV version of this:
www.dirtysixer.com
My own dream e-bike would probably be more like a hotted up 36er with a 4kW Cyclone driving the left crank Stokemonkey style, and a 3X3Nine hub.
Budget. Backlog of other projects. 3X3Nine hub apparently not available to mere mortals yet.What is holding you back actually building that dream bike?
Yeah I've been thinking about the same thing. Do you think a 2 speed would be good?Two-speed belt drive on the Sur Ron would be sick!!
Shift Drive is an ebike belt drivetrain that can shift gears
For vehicles like ebikes, belt drives offer a smoother, zero-maintenance alternative to chain drives. The Shift Drive system takes the technology further, by allowing riders to shift between two gears – plus it works on unmodified bicycle frames.newatlas.com
It's probably cheaper and easier to get all the same advantages and more by simply adding power and battery capacity. Multiple speeds for the motor only make sense if motor power is the limiting factor. If you're already riding an illegal bastard bike, what do you care? Just turn it up as much as you like.Yeah I've been thinking about the same thing. Do you think a 2 speed would be good?
Why not have both?It's probably cheaper and easier to get all the same advantages and more by simply adding power and battery capacity. Multiple speeds for the motor only make sense if motor power is the limiting factor. If you're already riding an illegal bastard bike, what do you care? Just turn it up as much as you like.
