motomech
quuxman said:Sunder said:I've only done high school physics, but something seems "off" to me. Given that the original motor is 350w, and this motor is 350w, the only way they can raise torque 30% is by reducing speed 30%.
I've been doing a lot of reading on the QQ series motors, because I'm about to buy one. The Q100H actually has about double the reduction ratio of the Q100 (1/12 vs 1/6th IIRC), and so really does maintain about the same RPM with 30% more torque. However, given the same controller, the Q100H is much noisier, and some have actually downgraded back to the Q100 after purchasing the "better" 100H for this reason, AFAIU.
I'm leaning towards the smoother, quieter, less torquey one, because it's reported to fairly easily drive at 20mph in a 26" wheel, on 36v 15 amp (max) controller.
That post was from the beginning of this thread, Nov. '13 and was answered, in part, by the next respondent, D8veh.I've only done high school physics, but something seems "off" to me. Given that the original motor is 350w, and this motor is 350w, the only way they can raise torque 30% is by reducing speed 30%.
WRONG. The "H"comes in two motor speeds, 201 and 260.The Q100H actually has about double the reduction ratio of the Q100 (1/12 vs 1/6th IIRC)....
These Q100 reduction ratios have been physically checked to be;
201H-15.7 to 1
328 standard-10.8 to 1
And until I can inspect my 260H motor, I am assuming the ratio is at, or close to, BMS Battery's claim of 12.6 to 1.
Since you do not specify which H model and which standard Q100 you are comparing, it's impossible to know what you are refering to, but there are no two Q100 versions where one has double the reduction ratio of another.
WRONG If the RPM has not changed, what you are talking about is actually "thrust", a value more correctly considered to be a function of motor efficiency.... and so really does maintain about the same RPM with 30% more torque
"Torque" is more closely related to mechanical leverage. Torque and thrust together can be thought of motor "Power" output.
At any rate, nobody that I am aware of, has thought the H models have 30% more POWER. D8veh, a very respected tester, felt it was more like 10%.
It is difficult to do a direct comparsion because the only direct comparsion would be the standard 201 to the 201H, where they use the same reduction ratio. This would eliminate the "torque" factor and allow one to focus on the "thrust" factor, ie, motor efficiency.
WRONG!! I have gone back and forth between the standard Q100 and the H with the same controller, and if there is any difference in sound between them, it beyond my range of hearing. As near as I can tell, they sound exactly the same.However, given the same controller, the Q100H is much noisier
WRONG. the standard 201 does 18 mph in a 26"wheel @ 36 Volts...because it's reported to fairly easily drive at 20mph in a 26" wheel, on 36v 15 amp (max) controller.
The standard 328 might reach 22 or 23 mph before it becomes current limited, but this is too high a motor speed for that size wheel and is not recommended.
A 260H in a 26"wheel on 36 Volts will do 20 mph.
I don't know exactally where you have been reading to pick-up so much mis-information, but I would recommend you start reading here or Pedelecs UK and try and stay away from those Russian forums.
