torque arm picture thread
Some dropouts are more accommodating than others. Here's last night's installment. Easy! (After filling out the torque arm for a 16mm axle, anyway.)
The bike probably don’t need any but put one on each side nonetheless. It’s nice when taking the wheel off/on it goes back to the same spot. I was fortunate that there was already a M6 tapped hole for the bolt. I will be using a pet trailer now and again and the torque arm will keep the axle from ever moving. IMG_5334.jpeg
Work in progress, motorcycle isn't yet finished, but here's what I have so far for a torque arm, for a QS273.
Stress lines for clamping force, yes or no? I think yes, based on what I've seen in the thread.
I think you are referring to the relief slot you cut there at the closed end of the pinch clamp TA. Slot could be a little wider (try about twice as wide as what you already cut), and drill a small stress relief hole at the its closed end (as you have seen in the other's photos).
Looks Good! :bigthumb:
Thanks, that is what I'm referring to. I'll get on it
here's my design of a front hub motor torque arm
there are two arms to hold the +/- torque
inspired from one of the pics in the first post in this thread
