Hello gentlemen!
Finally, I read the whole topic, it was much more than on TSDZ-ESP32:]
@casainho / rananna / beemac / Headless / all others.
I am impressed with your work as well as the idea put into the project!
Thanks for all your time!
Thank you also @bikelpl without his videos I would not have found this part of the internet ;D
I am starting to complete the necessary parts, but before buying, I wanted to ask about
one very important thing for me.
Will I be able to turn on / off Street mode from the DIY wireless remote level?
You added Turn on / off, Walk assist, Change assist level but I haven't seen anything about Street mode; /
I also have some suggestions about Street mode.
Would it be possible to add a password or confirm the exit from this mode on the mobile application?
Something like a popup asking "are you sure you leave Street Mode?"
My point is that an unauthorized person could not exit this mode without confirmation from the owner.
Of course, it could be optional, to be marked in the settings by the end user.
I hope you will like this idea:]
@Frzoen
I can see some board improvements if you agree to them.
1. Adding a circuit for lights with a voltage higher than 6v and high current consumption.
(currently in tsdz2 we are very limited when it comes to lighting, which is quite important)
2. Addition of pads for the external temperature sensor.
As in TSDZ-ESP32,
(here request to @casainho and @Headless to add a reading from this sensor and check the correctness of the circuitry on the board, if you find it interesting)
at this point we would release the pins on the original engine controller.
3. Removal of unnecessary GND for additional buttons and changing from 4 connectors to one smaller JST, or leaving only the solder pads.
(I know you won't be looking very well at removing the connector).
We'd save room for some MOSFET for the light circuit.
4. Optimize the size of the board in terms of space in the engine.
5. Adding connector to external antenna. I'm pretty sure the motor housing will jam the blue tooth a lot.)
6. It would be good to stick to the freely available components as previously written by casainho.
I like DIY and I would like to do the board myself, probably a lot of people will also want to have this option.
I think that's all that could be improved / added at the moment.
Write what you think about it.
I keep my fingers crossed for the success of this project, gentlemen, you are very close
I greet and have a nice evening!
