You were right!! I had to change the board type on the Makefile. Then, If I press the buttons to enter the bootloader, the firmware works as I see the debugger stop and then I see the bootloader active.rananna said:how about GPIO pin assignments?
Are you using the MDK board?
Yes, a long press of the plus button will write a flag to start Bluetooth in flash and then resets the board to load Bluetooth. A reset was the easiest way to clear ant and Bluetooth mem usage.casainho said:rananna said:how about GPIO pin assignments?
But if I long press the PLUS button, I always see a reset because I have a breakpoint at begin of main(). So, what can be the reason?????
Ok, it works at least when I force ebike = 0 and garmin = 1.rananna said:Yes, a long press of the plus button will write a flag to start Bluetooth in flash and then resets the board to load Bluetooth. A reset was the easiest way to clear ant and Bluetooth mem usage.casainho said:rananna said:how about GPIO pin assignments?
Try the compiled version now without debugging to see if it works.
Good news - we got there!casainho said:Ok, it works at least when I force ebike = 0 and garmin = 1.
Previous I saw the reset because it effectively resets after long press on PLUS!!
Tomorrow I will test more.
I'm glad that you got everything working.casainho said:So, the assist level changing on the wireless remote works very well, no missing clicks even if on the mobile app or on the Garmin Edge there is a delay showing the value:
When I implemented the remote, I had this compatibility in mind.casainho said:When we say that we would like the system to be easy to install, then we must consider and recommend to users buy instead a commercial remote and that means we need to develop the system thinking on that (this is part of advantages as also need to use standards) - our remote must behave similarly:
I would also like to see pwr on/off implemented.casainho said:But our remote can have some extras that will make it better but will not invalidate the usage of commercial ones:
- connection for the brake sensors
- we can show some information to users using the RGB LED
I agree, the system should be able to function without the android app or the remote.casainho said:I think the wireless board should have a big press button and the RGB LED, for things like:
- turn on/off the system with long press
- change the assist level with 2 quick press
- see assist level with quick press (will blink the LED xx times for assist level from 0 to 7)
- some way to select show the battery state using the LED blinking xx times
- RGB LED blink every time assist level is changed, brake is active, etc.
This would mean that only the wireless board is the necessary part, no even the remove, so, no afraid of battery fail because of being discharged.
Well that is a lot better than the -13C I woke up to in Canada today!casainho said:Next step is to validate current wireless board (it is raining a lot on this days, is hard to go outside to experiment all this
This will be tricky. Perhaps use transparent/translucent plastic box covers so that the LED is visible and the boards are protected from weather? Can you 3d print in transparent plastic?casainho said:and then start to document as also design the smallest 3D printed box for it, keeping the RGB LED accessible to be seen but also block the power LED (the RGB LED can also be used as power state, like with small PWM value so small light and increase the brightness for the other states like show assist level changing or brakes). The only extra thing to add to current schematic is a big press button.
Also there is the 3D printing design, that must be done, for the box case for the wireless remote, that must be small as possible and show the RGB LED.
The good news is that this is another advantage of the Nordic dongle.casainho said:Do you know if on your wireless board, the power LED can be eliminated, to save the power?
So, looking at the Garmin, there are 3 buttons with click on each one and long click on 2 of them:rananna said:When I implemented the remote, I had this compatibility in mind.
The current functionality of our remote duplicates buttons 1-3 of the garmin remote exactly.
Sure, seems the Garmin remote supports that also.rananna said:I would also like to see pwr on/off implemented.
This would be very convenient
Maybe just a hole for the LED and then user put a bit of white silicone or other white glue. In fact, this glue can be important to seal the box against the water.rananna said:This will be tricky. Perhaps use transparent/translucent plastic box covers so that the LED is visible and the boards are protected from weather? Can you 3d print in transparent plastic?casainho said:Also there is the 3D printing design, that must be done, for the box case for the wireless remote, that must be small as possible and show the RGB LED.
Good!!rananna said:The good news is that this is another advantage of the Nordic dongle.casainho said:Do you know if on your wireless board, the power LED can be eliminated, to save the power?
There are actually FOUR controllable LEDs on the nordic board!
LED_0 is a green power LED on one side of the board.
LED_1(red), LED_2(green), and LED_3(blue) are on the other side of the board
All LEDs can be controlled in code, including LED_0, eliminating any power draw.
I have done this for the remote control.
casainho said:Unfortunately, I am in Europe and buying that board from USA, that costs only 8€, I have to pay extra 20€ in shipping and most probably extra 50€ of taxes and work at the customs!!
Buying the board I have from China is much cheaper, about 12€ including shipping!!
Ok, did not know about DDP, I am used to pay a lot for customs when receiving from USA.plpetrov said:casainho said:Unfortunately, I am in Europe and buying that board from USA, that costs only 8€, I have to pay extra 20€ in shipping and most probably extra 50€ of taxes and work at the customs!!
This is only partially correct. There are also some some other details on the website that we need to need to look at www.digikey.be:
1. The price of the board is 8.44 Euro
2. The delivery terms are DDP. This means Duty Delivery Paid. This means customs clearance, duties and VAT are covered by the seller.
3. The delivery at least to Belgium is 18 Euro. However if you place an order for 50 Euro the delivery if free.
A bulk order of 6 boards costs exactly 50.64 Euro and qualifies for free delivery.
The MDK board on Amazon.DE is 19.99 Euro and to avoid paying for delivery you need to order two or to have a Prime subscription.
MDK board from China is 12.99 USD + 7.00 USD shipping or 19.99 USD in total. One board is under the legal limit in order to avoid VAT and custom clearance. For more, at least here you are charged VAT + min 20 Euro custom clearance by the local post.
After writing this, I found the same board all available at www.rs-online.com, eu.mouser.com and also other similar web shops.
casainho said:As you say, will be need more software developments. Who would want more work to do?? And seems you are duplicating, since the wireless board will connect to the TSDZ2 display connector, if you want to exchange for the 860C display, you just unconnected one and connect then connect the other.beemac said:Another thing I liked about the ESP32 is the tx/rx passthrough so you could use the usual physical display too. That to me seems useful e.g. if your phone broke for whatever reason you could plug in an 860c and carry on...
casainho said:Ok, did not know about DDP, I am used to pay a lot for customs when receiving from USA.plpetrov said:casainho said:Unfortunately, I am in Europe and buying that board from USA, that costs only 8€, I have to pay extra 20€ in shipping and most probably extra 50€ of taxes and work at the customs!!
- www.Mouser.pt: shipping costs 20,00 € and DDP
- https://pt.rs-online.com/: I can only register if I am a company, so, seems they do not sell to individuals like me
- www.pt.Farnel.com: out of stock
The lowest price of MakerDiary board, is 13.5€ per unit, shipping included (found on Ebay and Aliexpress).
The Nordic board at www.Mouser.pt: 28.5€ -- more than twice the price.
raw said:AZUR said:Casainho,
I hope it works with a 63V battery.
I invested a lot in 2 battery and 2 charger with 63V (15S).
sure, as long as you get a proper step-down converter that is able to handle 63v as input and output 2 - 5,5v.
casainho said:- https://pt.rs-online.com/: I can only register if I am a company, so, seems they do not sell to individuals like me
beemac said:casainho said:- https://pt.rs-online.com/: I can only register if I am a company, so, seems they do not sell to individuals like me
RS will sell to individuals no problem - I buy from them all the time. £10/11EUR at the moment in stock. https://uk.rs-online.com/web/p/wireless-adapters-wifi-dongles/1769054
Next step is to validate current wireless board (it is raining a lot on this days, is hard to go outside to experiment all this) and then start to document as also design the smallest 3D printed box for it, keeping the RGB LED accessible to be seen but also block the power LED (the RGB LED can also be used as power state, like with small PWM value so small light and increase the brightness for the other states like show assist level changing or brakes). The only extra thing to add to current schematic is a big press button.
Also there is the 3D printing design, that must be done, for the box case for the wireless remote, that must be small as possible and show the RGB LED. Do you know if on your wireless board, the power LED can be eliminated, to save the power?
I am not sure you are thinking the same about the 860C buttons...plpetrov said:That is already a big step in the right direction. A nice opportunity will be to reuse the code for the buttons form the 850/860 display. This will give the user the option with no change on the existing wiring to remove the existing display and to connect the wireless board box to the buttons and to the motor. The buttons can have exactly the same functions.
+ short press - change up the assist level; long press - switch on/off the headlight;
- short press - change down the assist level; long press or hold - walk assist mode
Power is power like you suggested above.
For the RGB led a nice option is ws2812b. It costs peanuts and exit in both RGB and RGBW versions. It is widely used in many hobby projects, so you can easily find and reuse the code. Requires only one pin.
If you do that I will immediately start testing. I have the required cables and will design and print the required 3D printed box.
Thanks!! For now I already bought the board, should arrive on MondayWaynemarlow said:Casainho, if you need any parts from RS just ask, we can always post them out to you in Portugal as presents and avoid customs duties. RS is not always the cheapest but one of the most reliable of suppliers. Farnell is also really good.
As we discussed previously, we agreed to standardize on the Nordic board for both performance and user adoption reasons.casainho said:If LH006453446HK complain, maybe we need to rethink to suggest the MakerDiary as it is the cheapest on Ebay sent to worldwide. But yes, if users can access to the Nordic board, that will be much easier for them, at least for the remote.
rananna said:As we discussed previously, we agreed to standardize on the Nordic board for both performance and user adoption reasons.casainho said:If users complain, maybe we need to rethink to suggest the MakerDiary as it is the cheapest on Ebay sent to worldwide. But yes, if users can access to the Nordic board, that will be much easier for them, at least for the remote.
The price difference is at best a few dollars worldwide; ie: Currently both boards are priced within $2 on Ali Express for delivery worldwide from China.
For North American users, the Nordic board can be bought for as little as $13usd with shipping, almost 1/2 the price of the maker diary board.
The Nordic board has easier reset options, (2 buttons), better power performance, and led control options.
The two boards also have different form factors, which would affect 3d design for packaging
Overall, the cost this wireless ebike implementation for both the remote and the wireless controller is a tiny fraction of buying a comparable wireless ebike. I don't thing we want to complicate adoption and ongoing support by recommending multiple boards.
Yesterday I just found the Nordic board for more than twice the price on EBay. Yes, I just verified on Aliexpress, that is correct, the price of both boards there are mostly similar - this information needs to go to the wiki!!rananna said:As we discussed previously, we agreed to standardize on the Nordic board for both performance and user adoption reasons.
casainho said:I am not sure you are thinking the same about the 860C buttons...plpetrov said:That is already a big step in the right direction. A nice opportunity will be to reuse the code for the buttons form the 850/860 display. This will give the user the option with no change on the existing wiring to remove the existing display and to connect the wireless board box to the buttons and to the motor. The buttons can have exactly the same functions.
Well, it is early to design the box for the TSDZ2 wireless board, maybe in 2 weeks I will get it tested and final. For now, only the wireless remote hardware is finished, so please go ahead and design and 3D print the for for it:
