casainho
- Joined
- Feb 14, 2011
- Messages
- 6,047
New release 860C_850C_SW102_v1.0.0-alpha.3 with changes only for solve the issue with the lights: https://github.com/OpenSource-EBike-firmware/Color_LCD/releases/tag/860C_850C_SW102_v1.0.0-alpha.3
Changelog:
- added configuration for lights ADC current step
- added battery ADC steps to configurations technical menu (to help user find the amount of battery current ADC steps that his lights pull)
2. On the display, enable the lights as usual
3. Go to configurations, Technical and see the very first value of "ADC battery current / ADC bat cu". This is the amount of current your lights pull.
4. Go to configurations, Various and on "ADC lights offset / ADC lights", set the previous value. I do not expect to be more than 4. And please report here the value you did configure.
Please report here if this worked and please test later on 4. every value from 0 to 4 and see what works and not so maybe I can use a fixed value and remove this configuration OR use as default value.
Changelog:
1. Install this alpha.3 versioncasainho said:If you need help ... write to mecityboy19 said:I will focus next on this. I don't have lights to test but I know what is the issue. The TSDZ2 motor controller has only one sensor to measure the battery current and that also includes the current on the lights. The firmware is not accounting for that and so gives that issue. I plan to make an option to see the ADC value of the current sensor and user see the difference and configure that value BUT use a default value that may work for most of the users. I think it will be something like 1, 2 or 3 ADC units and then maybe used always a fixed value and remove this configuration.
