TSDZ2 OSF for all displays, VLCD5-VLCD6-XH18, LCD3, 860C-850C-SW102.
hello, everyone, I'm a new user of TSDZ2B, and try to update to OSF v20.1 C.6.
but I met a connecting problem.
As the uploaded images, my speed sensor had two cables,
I don't know which one should I connect to ST-link dongle...
Did anyone have the similar setting of two speed sensor cables?
And which one is suittable for flashing OSF?
Many thanks for your help.
View attachment 369698View attachment 369699
You need to follow where the 2 cables go: number 1) should go into the motorhousing (to the controller), the other one - 2) goes to your lights.
You need to connect it to 1)
Ah - @dgc was faster ;)
  • Like
Reactions: dgc
New version update for stock displays (with configurator).
v20.1C.6-update-1, this is the list of changes:
1 - Added TSDZ8 to the configurator (for mstrens version).
2 - Fixed motor phase current bug.
3 - Added EKD01 display.
4 - Choice of the fifth level, for displays that support it, before ECO or after TURBO.
5 - Fixed issues with parameter setting and data display.
7 - Improved automatic and manual SOC reset.
6 - Improved torque sensor calibration procedure.
9 - Added delay to E02 error (torque sensor).
The manual SOC reset and torque sensor calibration procedure are much simplified.
For those who want to try, it is on GitHub as a master version:
https://github.com/emmebrusa/TSDZ2-Smart-EBike-1/archive/refs/heads/master.zip
Great, @mbrusa ! I just uploaded it and it seems to work fine.
Especially great is your new calibration procedure, which works without reprogramming, just via the display!
(At least that is how I understood it and how it seemed to work for me)
As always - thank you!
I am amazed what kind of optimization you are still getting out of this old controller.
Talking about product lifetime - none of my phones have such a long software support. :))
Must be one of two things, a good controller to start with or a very good programmer or perhaps a bit of both. I can remember doing spreadsheets on a IBM XT / 286 computer calculating pressure ramps against time for industrial processing, my mobile will do it in a flash took 5 minutes on the 286.
386dx33 first PC after atari 800xl i was10 and learned basic on it
Strange, I with "Assist Whitout pedaling" enabled, as soon as I put my foot down the motor starts.
Try posting the ini file obtained from the compilation (zipped).
but I have the same on 20,C5 on the SW102...
Let me ask you, what does "old controller" mean?)) It may well be enough to control not only the motor of a bicycle, but also the systems of a SAM missile)) So "old"... it's a bit of a mouthful) It is quite enough to control this type of engine and newer ones. Yes, the world of electric bicycles is gradually switching to the CAN bus system, but that's another story.
p.s. and well, you can call all this old, unless something truly new comes out)) So far, I don't know of any compact, lightweight mid-drive motor with a torque sensor...
Settings for tsdz2b close of bosch performance line cx
here are my settings
i have a bosch performance line bike too... these setting give tsdz2b a comportement close of bosch
Idea is to set hybrid eMTB (eMTB level are used) / torque (torque levels used), to put max RPM for ramp 90 or100 (so you want you run high RPM with assistance)
My setting are legal street mode (250 W 25km/h).
Warning: use patched hybrid mode (hybrid torque mode eMTB power based).
  • patch hybrid torque emtb_power.7z
  • ebike_app.c
What I was referring to is the old µController used in this Motorcontroller: An 16MHz 8-bit STM8S105. Sure you can do a lot with an 8 bit µController - but for a true FOC algorithm, which 'modern' 32bit µControllers can handle and which make the motors really efficient and quiet, it is just not powerful enough.
Only due to the smart people like @casainho , @stancecoke , @mspider65 and @mbrusa we have now a firmware which does sort of FOC on this 8 bit system.
I was not referring to the complete TSZD2 as 'old'!
I agree that this is still one of the most economic mid-drive motor with torque sensor. And almost everything is DIY repairable with many standard parts incorporated. (I even re-wound one of the torque-sensor-coils once when it was broken - as well as repairing the sensor itself by replacing the (std.) Hall Sensor in it)
Hi @endlessolli, yes reading the torque sensor is now easier.
The complete calibration is done by inserting the values of "Pedal torque adc offset" and "Pedal torque adc max" obtained with the new procedure into the configurator, and enabling "Torque sensor adv.", "Calibrated", "Estimated", all three. This is the recommended procedure.
It is true, the new calibration procedure can be completed on the display without reprogramming.
But it is not the same calibration that is obtained by inserting the data into the configurator, the result is similar but there are some differences to consider.
With the display storage, the parameters "Pedal torque adc range adjustment", "Pedal torque adc angle adjustment" are ignored, the scale is always remapped to 160. While "Pedal torque adc offset adjustment" has a different operation.
This alternative calibration is used with "Torque sensor adv." disabled.
While with "Torque sensor adv." enabled, if the calibration has not been done also in the configurator, the motor will work without calibration.
I added this possibility because, over time, the torque sensor values change to the point of causing error E02, in that case a quick calibration "on the road" can be useful.
Dear @mbrusa : Could you explain (again?) how "Pedal torque adc range adjustment" works (when using the configurator calibration)?
As an example:
I use Power Assist and I have 'Torque sensor adv.', 'Calibrated' and 'Estimated' enabled.
I have entered measured values for 'Pedal Torque ADC offset (no weight)' = 53 and 'Pedal Torque ADC max (max weight)' = 143, so I have a (rather low) range of 90.
I assume, this '90' range is then mapped to '160' for 'Pedal torque adc range adjustment' = 0?
(and mapped to 133 with range adjustment set to -20 or mapped to 186 when set to +20.)
But what does that really do in terms of behavior?
With default value ('0'), I never can get my controller to deliver high Amperes, even with max pressure on the pedal. (compared to using no calibration at all)
How do need to change 'Pedal torque adc range adjustment' to give me more Amps at a given (high) pedal pressure?
In the direction of +20 or -20?
Idea is to set hybrid eMTB (eMTB level are used), to put max RPM for ramp 90 or100 (so you want you run high RPM )
Warning: use patched hybrid mode (eMTB hybrid).
I'm glad you found settings that satisfy you.
There is one thing that leaves me perplexed, and it is in almost all of your posts, the reference to 250W as maximum power.
I have never intervened because I have no intention of starting yet another discussion on the difference between nominal power and maximum power. You can find as many online as you want.
The maximum power of the Bosch Performance Line CX is 600W.
Hearing that a TSDZ2B with maximum power limited to 250W has a behavior close to Bosch, leaves me very perplexed. I don't know what to think.
As an example:
To get more assistance you need to set "Pedal torque adc range adjustment" +20.
More assistance means that the maximum power is reached with less effort.
The maximum power is limited by "Motor power max" and "Battery current max".
Keep in mind that to increase the assistance there are also the level parameters available, with Power assist up to 500%.
There is another parameter that you can try "Pedal torque adc angle adjustment", it was born with another purpose, but it can be used to change the response of the torque sensor.
A negative value decreases the reactivity at low cadence and increases it at high cadence.
A positive value increases the reactivity at low cadence and decreases it at high cadence.
Try +20 and -20, you realize what happens, then there are all the intermediate values.
Hey!
edit: solved, common ground was missing.
I am trying to flash my 860C with the OSF firmware, however I can't get the flash to start in the APT Burn tools. I downloaded it from here: APT Burn tools v1.4 - bikel.pl which is the only place I could find it. On the back it says V58, while on with the OEM firmware it says hardware version P1.3 so I used the " 860C_V13-v20.1C.5-1-bootloader.bin" from the github. I am using my battery for the power source and have wired in a FT232 USB TTL converter, and I have seen someone mention they used this? as well as the flashing guide saying any USB TTL should work.
When I wire TX to RX and RX to TX:
I open the port, select the firmware and start the update both TX and RX values go up, if I press or hold the power button the RX stops briefly and then starts back up again. If I hold the power button it also boots the OEM firmware and as stated before the RX continues.
Wiring RX to RX and TX to TX
Opening the port, selecting firmware and starting the update first the TX value only goes up, but then the RX also starts to go up? pressing or holding the power button makes the pause of "rx not going up" to last longer, however after a while it starts going up again. Holding the power button like this does not turn the display on at all.
I have only wired the P+, GND, RX and TX, not the VIN. I also never connected the GND of the battery to the GND of the TTL converter, maybe this is my problem?
Edit: The common ground was my problem, managed to solve it, sorry for not trying that first before posting tho, only figured it out while writing.
I can't find anything about anyone having the exact same issue as me, any help would be appreciated! Once again; thanks for all the work you have put into this awesome project!
Thanks,
Philip
hybrid modification:
i tried to combine torque mode and emtb power based in a new hybrid function.
Better for eMTB.
Here is the new code of hybrid (ebike_app.c). you can modify manually before compile&flash or use patch (put in src folder)
to use you have to be in hybrid mode (javaconfigurator ). You can patch before using javaconfigurator compile and flash.
static void apply_hybrid_assist(void)
#define eMTB_ASSIST_DENOMINATOR_MIN 10 // Minimum denominator for eMTB assistance calculation
uint16_t current_target_from_torque = 0; // Target current from torque assist
uint16_t current_target_from_power = 0; // Target current from power assist
uint16_t current_target_final = 0; // Final target current (in ADC steps)
uint8_t emtb_mode_parameter = ui8_riding_mode_parameter_array[3][ui8_assist_level];
// Smooth start block (if needed, uncomment below)
// #if SMOOTH_START_ENABLED
// apply_smooth_start();
// #endif
// Check for assistance without pedal rotation:
// If the system is configured for no-pedal rotation assist, and no cadence is detected (0 RPM),
// yet the pedal torque delta exceeds a threshold, then simulate a cadence of 1 RPM.
if (m_configuration_variables.ui8_assist_without_pedal_rotation_enabled) {
if ((ui8_pedal_cadence_RPM == 0U) &&
(ui16_adc_pedal_torque_delta > (120 - ui8_assist_without_pedal_rotation_threshold))) {
ui8_pedal_cadence_RPM = 1;
// Force assistance when an error flag is set:
if (m_configuration_variables.ui8_assist_with_error_enabled) {
// If there is pedal activity or startup-assist is active, then calculate the assist:
if ((ui8_pedal_cadence_RPM > 0U) || (ui8_startup_assist_adc_battery_current_target)) {
// --- Torque-based assist (immediate response) ---
if (ui16_adc_pedal_torque_delta > 0U) {
uint8_t torque_assist_factor = ui8_riding_mode_parameter_array[TORQUE_ASSIST_MODE - 1][ui8_assist_level];
current_target_from_torque = (ui16_adc_pedal_torque_delta * torque_assist_factor) / TORQUE_ASSIST_FACTOR_DENOMINATOR;
} else {
// --- Power-based (eMTB) assist (progressive response) ---
uint16_t assist_denominator = (508 - (emtb_mode_parameter << 1)) + eMTB_ASSIST_DENOMINATOR_MIN;
if (assist_denominator >= ui8_pedal_cadence_RPM) {
assist_denominator -= ui8_pedal_cadence_RPM;
else {
assist_denominator = 0;
assist_denominator += eMTB_ASSIST_DENOMINATOR_MIN;
uint16_t effective_delta = (uint16_t)(
(((uint32_t)ui16_adc_pedal_torque_delta * ui16_adc_pedal_torque_delta) + assist_denominator)
/ assist_denominator
current_target_from_power = effective_delta;
// --- Select the maximum contribution ---
if (current_target_from_power > current_target_from_torque) {
current_target_final = current_target_from_power;
} else {
current_target_final = current_target_from_torque;
// Apply the motor ramping (smoothing of acceleration/deceleration)
set_motor_ramp();
// Limit the final current target to the maximum allowed value
if (current_target_final > ui8_adc_battery_current_max) {
ui8_adc_battery_current_target = ui8_adc_battery_current_max;
} else {
ui8_adc_battery_current_target = (uint8_t) current_target_final;
#if STARTUP_ASSIST_ENABLED
// Startup assist: if startup assist flag is active, adjust the current target accordingly.
if (ui8_startup_assist_flag) {
if (ui8_adc_battery_current_target > ui8_startup_assist_adc_battery_current_target) {
ui8_startup_assist_adc_battery_current_target = ui8_adc_battery_current_target;
ui8_adc_battery_current_target = ui8_startup_assist_adc_battery_current_target;
} else {
ui8_startup_assist_adc_battery_current_target = 0;
#endif
// Set the PWM duty cycle target. If current target is nonzero, apply maximum PWM.
ui8_duty_cycle_target = (ui8_adc_battery_current_target) ? PWM_DUTY_CYCLE_MAX : 0;
  • ebike_app.c
Better for eMTB.
// #endif
} else {
else {
} else {
set_motor_ramp();
} else {
} else {
#endif
It would probably be good if you start a separate thread for your modification suggestions.
Orherwise is gets very hard to follow this thread. Also, people interested in your changes can find those easier.
Just a suggestion.
Hey!
Thanks,
Philip
We have already talked about powering the display from the battery.
Even if you power the display with an external battery, you must also connect GND.
Possibly try to invert TX with RX.
860C V1.6 is a version that I do not know, try the file 860C_v20.1C.5-1-bootloader.bin, it is for version 2.0 but it could work.
Finally!! Thank you!! It was a ground problem! It flashed no problem.
Hi,
I just flashed OSF v20.1C.6 on my TSDZ2b (250W / 36V).
After biking a bit, I started getting E07 errors (overcurrent).
Any idea where it could be coming from?
I just observed I didn't change the street power limit to 500W.
Should I restrict it too ? (to 250W?)
Hi,
I would say yes... legal is 250w nominal.
Hi,
Limiting the maximum power to 250W is, in my opinion, an unnecessary precaution.
If you purchased the 36V/250W motor, there is no problem. Just set "Motor power max" and "Street power limit" to 500W, it is the peak power that can be higher than the nominal power.
Keep a document, purchase or delivery, with the description of the motor, it is important that 36V/250W is present.
It would also be useful to have 250W on the motor plate, but few retailers do this.
The most important thing to comply with EU regulations is the maximum speed assisted by the motor, so "Max speed offroad mode" and "Street speed limit" must be set to 25km/h, also "Set max speed from display" must be disabled!
I would avoid the throttle, even if some operating modes are allowed.
E07 unwanted overcurrent error, may be caused by setting the maximum power to 250W, if it happens again, try increasing the "Overcurrent error delay" value by one unit at a time.
Question for @mbrusa:
Max current isn't set according to max power configured by javaconfigurator (firmware) wich compare calculated current to max battery current to max possible allowed ( I=Pmax/V Battery mesured ) choosing minimum of 3 values ?
Setting 500w won't increase Pmax/V Battery and so increase max possible value?
Edit: reading code I don't see where it enable burst and where street mode is blocked to 250w nominal if you set more in javaconfigurator...
Yes ... they power on motor on a bench. They mesure speed and power. If they mesure 25 km/h max with assistance and 500W nominal (they use the motor as it, they dont change firmware) what happens? 500w mesured ? No insurance. Fully responsible. Insurance do whatever they can not to pay.
I have a relation who's husband is dead. Just a drink too much driving. Nothing but just a little above legal limit. Insurance didn't pay. His wife had nothing , a credit to pay for home, 3 children.
Who asked expertise? Insurance of loan...
And they didn't pay...
In EU sticker on bike isn't an obligation. Motor has to be certified and mounted according the registration.
I really would like to ask to keep these discussions out of this thread.
@Elinx and @mbrusa have a lot of experience and shared their knowledge wrt this topic.
Still we all know, this 'what is legal?' discussion can be dragged on infinitely (and many have done this already - search the related threads, if you are interested).
So, if you want to continue this discussion, please use another thread.
This one should be dedicated to topics specifically related @mbrusa 's firmware.
Problem is this firmware somehow don't respect norme. For example you can have assistance after 25 km/h even if street mode with 25 km/h is active.
Read code. "+margin" allow assistance after limit.
Please keep thread discussions to topic; you're more than welcome to start a different thread regarding legality of different powered controllers and hacking them. We'd rather not have to lock this thread to cool it off.
