mrfunk said:
Using a VLCD5 display with v20.c
Now I feel a fool.. turns out it was working, I just needed to press the peddles, as throttle was disabled.. doh
i have it set too startup in street mode AND hybrid mode, I have somehow enabled throttle. i would say that assitance when peddling feels a little flat, and only kicks in when I peddle hard and fast.
Im looking to reflash but noticed STprogrammer cant read , getting read errors is the controller protected once flashed.? or once flashed, you cant use ST programmer to read, and hence can only use the Java?
Im doing my best to understand the manual, but i cant work out how to simple select a different mode.. such as power assist. so wish there was a video.
Vlcd5 is clear, FW v0.20.1C .
This means you need some experience to change the modes with the buttons and understand what happens if you push the light button several times. Lots of practice is the only way. till you see it. After this you do it within seconds when biking
About the flat assistence it could be you have a bit less sensitive torquesensor.
With a software calibration it is possible to improve this.
But also in that case you must do the light button dance
with the vlcd5
Light button dance:
-For changing E02 click 2x
-For changing E03 click 2+2 (4x)
-For changing E04 click 2+2+2 (6x)
If flashing of E0x stops, the setting is changed
Examples:
-Streetmode off (or on): Level 1 - E02 Push light 2x wait till E02 stops flashing....done
-Power mode on: Level 2 - E02 Push light 2x wait till E02 stops flashing....done
-Torque calibration (see page 4 of the manual):
Level 1 - E04 = light 2+2+2 wait for flashing, push light again 2x
read zero load (3 digits)
push horizontal pedal with full weight
read max load (3 digits)
Normaly you flash the controller with a script from the java configurator.
You eventual only need STV programmer to check the wire connection before flashing with the configurator.
The script set up al the STVP configurations with cmd.
Be sure you shut down the Windows version before you hit "compile & flash".
Stock FW is flashed with STVP setting STM8S105x4, with the Window version
OSF is flashed with STM8S105x6, with the java configurator
With the wrong setting (windows) or wrong flash sequence of the 3 tabs you got the red errors
(see the link from raylo32 for additional info about flashing)
With the java configurator this is full automated (by cmd script).
