scrambler
Artur said:
Good Looking Fat Bike!
You should add it to the list of full bikes available on the Vector site.
Artur said:
dvdrwsor said:Thank you macribs! I'll check it out.
@scrambler
Arthur should answer this, but as I'm at page 45 of his dedicated thread, what I can tell is the different models were an early days concept that was discarded shortly. Now there's only Typhoon v2.0 if you get the entire bike from Vector, or you get the Vector frame and the parts that you want from Arthur, and the rest from somewhere else. Arthur answered that a few times on his thread, now he doesn't bother as much. I think he should edit his first post on his thread.
The components that he sells are better than average, and have a good price. You can always ask for a specific mod on the frame, including vents.
I don't like permanent vents, so what I was thinking is buy a few rare earth 2-3 mm magnets, and put them as spacers for covers when the weather is too hot. A quick on and off mod. And when off season, or the rain starts, take them off.
MAGNETS On the right, under the price, you can find different sizes.
Magnets are also good to "glue" a mini plastic self sealed bag on top of your frame, and in the bag to put your phone or keys, or whatever.
scrambler said:Two quick questions for Artur regarding the current Tornado and Typhoon configuration.
Initially the Tornado was shown with the controller inside the frame and vents on the side covers, while the Typhoon was shown with an external controller and no vents.
Today it looks like both bikes are using the same battery, so are they still configured that way, or is the Typhoon now configured with the controller inside and the vents?
Also, if the Typhoon still has the Controller outside, would having the Vents on the side cover still be beneficial to cool the battery?
Thanks
Artur said:At the moment all 3 models are the same, just with different controller. (Mini,Midi,Max)
scrambler said:Artur said:At the moment all 3 models are the same, just with different controller. (Mini,Midi,Max)
Thanks Artur, but that does not fully answer my questions
Are they all with the controller inside and the vents, or all with the controller outside and no vent?
ThanksArtur said:scrambler said:Artur said:At the moment all 3 models are the same, just with different controller. (Mini,Midi,Max)
Usually we mount controller outside behind the controller shield. and we using side covers without vents, nut like macribs said - we cam do whatever customers want
Artur said:I will ask to make a photo for you, the new batteries arrieve in 7 days.
lionelt said:Hi all,
order for Vector frame and parts are done. very impatient, already received MXUS V3 4T, 18Fet Lyen, 6S 20AH HK x 3...
Preparing other parts for mount my ebike :
1 - what's specs of front hub dual disc (vector), i see 18 holes for spokes, i need diameter... all for finding which rim can i use ?, if you have some reference of rim and spokes for this hub
2 - DNM fork (vector), is it possible to use a 27.5" wheel without lost 200mm ?, because there are lot of choice about tyres (i use 26" at rear with mxus V3)
thanks for your help reply
DasDouble said:Hello Artur, have you already thought about some custom footpads for second passenger for moto-seat option?
Can you make custom Moto seat-passenger hand grips?
I would love to order some from you.
-Elias
We will add your design to the listBigDm said:The black areas on the side covers are just stickers for decoration.
BigDm said:My new toy
Frame: Vector
Fork: DNM Volcano USD-8 all black edition - 1 1/8
Rear suspension: DMN Burner 3 - 220mm
Headset: FSA The Pig - 1 1/8 " Standard
Seat post: Radon Light 400mm - 31,6mm
Saddle clamp: Hope - 36,4mm
Crank: Shimano ACERA for 7/8x FC-M361 48/38/28 Vierkant - 175mm
Chainring: Race Face Narrow Wide for 9 / 10 / 11x - 104mm 38 teeth
Chain: Shimano XT / Ultegra 9x CN-HG93 114
Rear derailleur: Shimano ZEE 10x SRD-M640-SSW Shadow Plus
Shifter: SRAM X9 - works perfekt with 9 speed cassette and Zee 10 Speed M640 derailleur
Cassette: SunRace 9x freewheel 13-32
Brakes: Shimano ZEE BR-M640-B
Discs: Shimano XT SM-RT86L 203mm 6 hole
IS to pm adapter for the rear brake: Shimano 203 mm SM-MA-R203P/S
Stem: Sixpack
Handlebar: Truvativ Holzfeller
Front wheel: DT SWISS FR 2020 20x110 26 Zoll
Tires: Maxxis Ardent 26x 2.7
Back rim: EXAL XL 25 - 26" BLACK Spoke hole diameter : 5,5mm = 12G spokes (from Crystalyte)
Spokes: 36x 164 mm 12G stainless steel black (from Crystalyte)
Motor: Mxus 3000 V2
Controller: HK Sunwin 72V 2000W - Rated 72V 60A Ebay: 391502430554
Battery: 6x Hobbyking MultiStar High Capacity 6S 12000mAh for 18S 2P
Charger: ALPHA TECHNOLOGIES AC/DC 100-250V DC OUT 54V CAR0948TN 7A
Voltage Converter Step Up Modul: 600W DC 10-60V to 12-80V Boost
Works great
Thank you for theseBigDm said:Here are 50 more Pictures.
https://1drv.ms/f/s!At6JsHhRVPg6gthQB999shfgjvSE0Q
scrambler said:Thanks
Is there actually room for the Max-E inside with the current 2.5kWh battery, and if so is there enough ventilation with the vents for average use of the bike?
