rexfordk83
- Joined
- Feb 25, 2020
- Messages
- 30
SilentEnduro said:rexfordk83 said:nice video!,
any reason to solder the sport mode? or just keep it simple since its the only mode you use?
for your busbar current you found 140 to be best?
for the qs 138 motor is your shift angle -60? I believe mine came from factory at -120
soldered sport mode just to keep it simple, no button needed
140 BA since i have shunt-mod (+30A)
regarding angle, there might be different depending on motor version.
150/2 is still under development and testing, not sure if it's possible to order one.nardcox said:Are you like a tester or is it out to the public?
Agreed with QS that I accept all risks, no warranty etc. =)
Im new to shunt mode, but can you tell me the advantages of the way you did it, instead of just raising the bus bar current to 170a in software. Im guessing raising it in software might not actually do any increase and by manually doing shunt mode will?
