BareKuda said:Your bike is actually made by ZongShen in china, two models available, 26ah with 4kw motor and and 40ah with 5kw motor:
http://m.cineco.cc/#/product_details?id=0&lead_product_id=127
In the picture showing the controller programming app, do you have that already? I cant find the controller yet but im looking. Based on the number is 84v100a but used in 72V, so it should be capable of 7200 watts peak which is fine for a 4kw motor.
Once you have the ability to program it, i think you can at least get the designed 70 kph and maybe more. Depending on how much flux weakening it can use effectively.
Hi BareKude!
Thanks, I made a lots of search and found the info I need here is my summary for this morning:
It turned out it is a rebranded motor: Lexmoto Cypher
It has a 1500W controller and 2000W QSmotor, not what M0tr0n seays in spec, it is not 3.7kW and not Bosch motor.
Code:
Specifications
OVERVIEW
Model Name
Lexmoto Cypher
Model Code
ZS1500D-2
PERFORMANCE
Max Power
(2.5 hp) 1.85kW
Max Torque
14.6NM
Max Speed
28 MPH (45 KMH)
ENGINE
Engine Brand
QS 1500W
Engine Type
Electric Motor
Engine Cooling
Air Cooled
Gear Type
Twist and Go
Drive Type
Belt
Start Type
Electric Start
Battery Voltage
72
WHEELS
Front Brake
Hydraulic Disc
Rear Brake
Hydraulic Disc
Front Tyre
110/70-12
Rear Tyre
120/70-12
Tyre Model
Tubeless
Front Suspension
Upside Down Forks
Rear Suspension
Monoshock
DIMENSIONS
Length
1760 mm
Width
810 mm
Height
1000 mm
Wheelbase
1265 mm
Mass in Running Order
84 kg
Maximum Laden Mass
250 kg
Original with the correct specification:
https://www.lexmoto.co.uk/models/ZS1500D-2
Here is a test of the original bike:
https://www.youtube.com/watch?v=xSbEGXSSIn4
Motor KIT from QSmotor:
https://www.qsmotor.com/product/mid-drive-motor/
The motor is the 2000W version in it with peak 4600W:
https://www.qsmotor.com/product/2000w-mid-drive-motor/
This method also worked on mine, everything is the same:
https://www.dundeescooters.co.uk/wp-content/uploads/2021/02/cypher-and-impulse-derestriction-guide.pdf
They changed only some colors and the balance charge port to M25, here this port is used, having CAN H and CAN L signals to be able to start charging or draining.
So not happy, I cannot charge it with my custom low amps slow charge solar panels
https://www.wellnowus.com/m25-215-male-scooter-socket-e-bike-battery-connector-ip67-30-50a-plug-with-cable-wire-chargingdischarging-batteries-plug-product/
So I could test de-restricted based on Cypher instructions, went until about 50-55kmph in ECO and 69kmph in POWER mode, but I was out of road so it could go above 70kmph a bit.
How to de-restrict the Lexmoto Cypher and Impulse
Ensure the ignition is off,
Hold throttle fully open and hold the front brake.
Whilst holding the above turn the ignition on fully.
Hold for 5 seconds
