Hardware temperature control tsdz2
this is how I did to my tsdz2 using aluminum insert:
1. Buy a 1mx25mmx1m aluminum bar from Bunnings.
2. Cut to shape using paper template.
4. install temporarily and remove, make sure the motor top surface touches the housing. I would say 1mm might not be thick enough, but 1.2mm is hard to be found, so I live with it. Better than the empty gap.
With summer here in Australia and high ambient temperatures I decided to do some of the heat dissipation mods in this thread. Ambient varying between 30-35 deg C. Motor would head reasonably quickly above 70 deg C stock.
I bought 1 x 80x40x2mm piece and 1 x 80x40x3mm piece of Gelid GP-Extreme thermal pads, and a 10g tube of GP-Extreme thermal paste. From https://gelidstore.com/
Also needed a length of 25mm x 1mm aluminium flat bar which was only a couple of dollars, and a reasonably chunky stainless steel hose clamp that would tighten to 65mm and that was probably 15mm wide, also a couple of dollars.
I followed the wiki guide for thermal compound inside the motor ends, and used about half the 2mm pad to fill the under motor gap. I used half the 3mm pad cut into 5 pieces to fill the gaps between the motor screws apart from the one closest to the controller. Roughly cut the flat bar to get two lengths that would wrap around the motor, and bent them around a tube of similar size. Installed them over the motor, with some thermal paste between the two layers. Slipped the pipe clamp over the top, also with some thermal compound between it and the aluminium. The screw mechanism of the clamp sits nicely between the motor and controller. Aligned it all so it sat low on the motor, and that gap between the almost full circle of the aluminium strips was over the single non-padded area of the stator and then tightened up the clamp. Stretched the rest of the 2mm thermal pad around the non controller side of the motor to fill in the gap to the outer case after checking the clearance. Used the rest of the 3mm pads as per the wiki on the top of the motor. The GP-extreme thermal paste is very thick, so had to use some cheap slippery thermal compound I had on hand to help slide the cover on. Tight fit but got it on.
Even with ambient temperatures in the low 30’s (C), after the mods haven’t been able to get the temp reading beyond 42 degrees. Super happy with the mods. All up around AUD$60. No special tools required. The aluminium flat bar will break if a sharp bend is bent back and forth.
Thanks to all in this thread for the great ideas!
Any pictures mate?
I bought the same flat 25mmx1m aluminum bar from Bunnings and made an insert to use between the top of motor and the housing:IMG_20231103_125144.jpg
But not sure what is the best way to wrap it around the motor body.
Thanks in advance.
Hi Everybody,
Noob here but I have learned a lot scanning/reading through this thread, thank you.
I’m hoping someone can recommend an online seller for decent quality and value thermal pads please? Bonus points if the seller is in Australia 🇦🇺.
Thanks 😊
Hi Everybody,
Thanks 😊
All Australian sold TSDZ2s (ebay and etc), if I am not wrong, are new version with new controllers due to legal restrictions, not ST chips anymore. So there is no way to use OSF.
I bought an old version controller from China (old stock) and swapped it in. Now I am running OSF with VLCD5, which is so much more fun than before.
They told me that they still have 50 of those, but I am not very interested in this, unless a lot of people want them I might be able to help.
All Australian sold TSDZ2s (ebay and etc), if I am not wrong, are new version with new controllers due to legal restrictions, not ST chips anymore.....
I bought an old version controller from China (old stock) and swapped it in. ....
This is new information for me. Till now only a German webshop sold another controller version.
In that case you must have seen the difference between these controllers.
The thermal conductivity of rubber is about 0,15 W/mk, so that is more than air (0,02 W/mk) but less than the cheap sticky silicon thermal pads (2 á 6 W/mk).
The metal BBs are between 2 layers of rubber, so I can't predict what the influence will be on the motor cooling.
FYI:
Copper 380W/mk, Aluminium 205W/mk, Steel 50W/mk, iron 80w/mk
So you understand the experiments with copper and aluminium
Elinx, I'd like to use a thermo switch such as Pepi N Series Thermal Battery Pack Switch +65C 5% 2.6 Amps @ 120 VAC USA Seller | eBay inside the motor, wired to the controller to cut out the motor. I want to keep the throttle thus cannot install the LM35 but still would like a cutout for the motor when it gets too hot. Is this possible and if so do you know where on the controller is the best place to connect this switch and whether I need a normally closed or normally open?
Edit: If not possible, I can connect it to one of the two brake cutout 3 pin connectors from the KT-LCD3. I would need to use a normally open thermal switch 5Pcs KSD9700 Temperature Switch Metal Thermostat Thermal Protector NO/NC 5A 250V | eBay
Continuing with my personal experiments...I bought this from Amazon: https://www.amazon.com/dp/B01F47W86C?psc=1&ref=ppx_yo2_dt_b_product_details. This stuff is pretty dense but just a very little compressible and about 1.5mm thick.
Then cut it in strips just long enough to wrap the motor and terminate at the controller. Taped the ends to keep pieces of wire from potentially going adrift and getting into the electronics. Then wrapped the motor center with one full piece and one that was ripped in half, then 2 more full wraps of the entire motor, taping the layers down with HVAC metal tape. I ended up using almost all of the 5' roll.
Tested on the same route as above, pushing the power even higher. The max temp reached was 155F (68C), a full 10 degrees F cooler than with the silicone. And the transition to cooling when the power was removed was notably faster as was the temperature drop with time. VERY noticeable. At the end of the ride that includes some downhill the motor was 12 degrees F cooler than the other day with the silicone. And the delta T between the case and motor was 12 degrees F whilst with the silicone it was 33 degrees F.
All in all, a very positive result and a fairly easy install. It would be easier still if we had this sort of material in a mat. I had a small issue with the last wrap bunching up a bit at one spot of the case so it didn't close flush. Not that I ride in the rain but I will open it up again and fix that. I may even try to weave or tape these sleeves together into a mat of sorts to make the whole process easier.
I remember from school physics lessons that copper is almost the best heat conductor. Therefore, I also consider such a solution to be the best, especially considering the price of such an upgrade.
p.s. with a perforated cases, inserting NASAspace tubes, or water cooling (from a PC?), etc. - I laughed more... but with respect (because, after all, everyone has their own hobby)
So, to continue - in fact, this is a very cool modification, because copper has the highest thermal conductivity(except for silver, but let's not exaggerate) - about 400 W/(m-K),
compared to the thermal pads -16-20 W/(m-K), that everyone sticks in their motors...
I am also very interested in copper "foam"
By the way, copper radiators/heatsink can also be glued/screwed on the outside:
Now I'm thinking about whether to try to make the mod with these "sponges" or wrap it with wicker...
P.S.
TZDZ2 Air Cooling
And this is a bit of a strange modification(for me)... unless you never drive in/after the rain...
The actual thermal conductivity of copper braid or foam will be a small fraction of copper's conductivity. If it will be more or less than pads depends on how much it is crushed and how dense it is but probably better if you fill it right up. Ideally you would replace all the air in them with something more conductive like thermal grease and you may get somewhere pretty decent without solid machined shims.
In general, with a power of 450-500 watts and weather temperatures of 20-25C( on 2-3 lvl of assist), I wouldn't say that the motor is that hot... slightly warm..
I understand that the motor core is hotter due to poor heat dissipation to the case, but if this heat dissipation is improved by at least 30-40% (for which even a couple of pieces of thermopads (and a small radiator from SD NVMe will suffice)), the power can be safely increased to 600-700 watts.
I think that it will be possible to burn it out only if you give the maximum 18A that the controller allows and go on a long climb at +30C on max lvl of assist... - but this must be done specifically on purpose.
Forgive me for not reading the whole thread. But I purchased a complete heat cooling kit from eBikestuff.eu. They are great to deal with. The shipping from Poland to the US has been reliable and the cooling kit is precisely made. They have two levels, one with only internal and one with the internal and additionally external cooling fins to move heat all the way out. Includes the info on installing the heat sensing chip to transfer internal temp to the 860c display.
Good install video on youtube for anyone interesting in modifying your Tongsheng.
The one posted here in 2023?
