Seeking Help: BLDC Motor Control Board Development (FOC Technique)
Hello everyone,
I’ve been trying to understand this concept for quite some time, but I’m still a bit confused — I’d really appreciate any insights you can share.
How does an op-amp measure negative current when using low-side current sensing?
I’ve done a lot of reading and research, but I’m still not entirely sure how it works in practice.
Specifically, I’m trying to understand:
  • In what situations does the low-side MOSFET conduct current [how opamp measure negative current?]?
  • When and how does the body diode conduct current back to the phase or to upper MOSFET body diode through body diode?
  • How is this reflected as negative current in the sense resistor and measured by the op-amp?
If anyone could help clarify this or point me to a good resource — like an article, application note, or video — that would be really helpful for my understanding. I’d be very grateful!
Thanks in advance!
BldcLover
The current though the motor is pseudo continuous. It changes slowly because of inductance.
The mos are sequentially conducting high side then low side, swapping very fast relative to the current change
So whether the current is flowing in or out of the motor, it will still be conducting through the low side shunt when the low side FET is conducting.
Hence you can measure it. You just bias the opamp so that 0A is mid rail... 1.65V usually.
It's that simple.
It's that simple.
Hi mxlemming,
Apologies for the delayed response — I’ve been feeling unwell recently, which led to a slight delay in my work.
In the meantime, I’ve been studying more, and based on my understanding, due to MOSFET switching, the motor doesn’t accept an instant change in current. As a result, reverse current may flow from ground to the motor phase — is that correct?
I’ve attached an image to illustrate what I mean; could you please let me know if my understanding is accurate?
I’m particularly confused about how the low-side MOSFET behaves during switching, and how exactly the shunt resistor measures current in this scenario.
Best and regards,
BldcLover
Hi stancecoke,
I'm planning to use your LishuiFOC firmware with my custom motor controller design.
Could you kindly take a look at my schematic and let me know if there are any corrections or improvements you’d suggest?
I've attached both the schematic and my gear motor for your reference.
Thank you in advance for your time and support!
Best regards,
BldcLover
Sorry, as written before, I'm not the hardware specialist. What I don't understand: there are half bridge drivers with voltage and current outputs, a bootstrap circuit and an opamp?! No idea how that should work....
regards
stancecoke
Hi stancecoke,
I have implemented a totem-pole gate drive circuit using NPN and PNP transistors for MOSFET switching, instead of using a dedicated gate driver IC. Since this discrete solution does not include built-in dead-time control or shoot-through protection, dead-time must be carefully managed in firmware.
When the PWM signal from the MCU is high, the NPN transistor turns on and activates the PNP transistor, which then drives the MOSFET gate to 12V. During the PWM off-period, a discharge path through the NPN transistor pulls the gate low, turning the MOSFET off and discharging the gate capacitance and mosfet across capacitor is act as bootstap cap.
For phase current measurement, I use a low-side shunt resistor. The small differential voltage across the shunt is amplified using an INA181 current-sense amplifier, and its output is fed to the MCU's ADC for accurate current monitoring.
To measure phase voltage, I use a resistive voltage divider to scale down the high voltage, which is then read by the MCU's ADC.
I also have some doubts regarding the firmware. Could you please review and let me know if my understanding is correct or if there are any mistakes?
Here is my understanding:
Initially, HAL_TIM_IC_CaptureCallback does not execute because no rising edge has been detected yet on the Hall sensor lines (through input capture).
When the autodetect() function starts, both ui8_hall_state_old and ui8_hall_state are globally initialized to zero.
At this point, with no valid Hall sensor input, the firmware applies a predefined id current (d-axis), which excites the motor windings in open-loop control mode.
Due to this excitation, the motor might slightly rotate or jerk, possibly drawing a temporary surge of current.
This movement may cause a Hall sensor transition, which then triggers the HAL_TIM_IC_CaptureCallback, and updates ui8_hall_state with the new Hall pattern.
However, since ui8_hall_state_old is still zero at this point, the autodetect() function immediately updates it to match the new ui8_hall_state.
Now, both ui8_hall_state and ui8_hall_state_old are equal, so no Hall case condition is met yet (no transition detected by if (ui8_hall_state_old != ui8_hall_state)).
The control logic will only act when the next Hall transition occurs (i.e., ui8_hall_state changes again), which is when expected behavior resumes — the correct case inside the switch executes and the rotor angle for that Hall transition is stored.
Best and regards,
BldcLover
Yes, that's the way it works. The rotor makes three electrical revolutions in open loop, only the angles of the hall switches during the last revolution are stored in the virtual EEPROM.
But not only rising edges are detected, but rising and falling edges. The STM32 has a special timer mode for reading BLDC hallsensors. This feature is used on timer2 in EBiCS.
GitHub is down in Europe since two days now :oop: , otherwise I could post a link to the relevant timer configuration line in the code....
You have a lot of weird stuff in your schematic. Weird stuff isn't clever, it's a source of complication and failure.
I advise you stop messing about with making your own gate drivers, you can't do it better than infineon, on semi... Or any of the driver makers.
You have a 30V diode on your DCDC. Are you really only running up to 30V?
Why are there weird diodes on the voltage sensing and temperature sensing?
Go dig out the vesc schematics for 75300 or my MESC schematics, or the mp2 schematics, read my threads on hardware development. If you're doing something significantly different, you should be asking yourself why.
Hi mxlemming,
I just started reading through your thread today, and I have to say I’m genuinely impressed with the incredible work you’ve done. you've done an outstanding job, and I can see the dedication behind your project.
As I’m currently learning more about FOC, I believe following your hardware and software design would be a great way to gain a solid understanding. For now, I’ve decided to put my own hardware development on hold so I can focus on studying your work and building a good foundation.
Once I reach a certain level of understanding, I plan to resume my own design with better clarity.
In one of your posts, you recommended using this specific commit from your GitHub repository:
🔗 GitHub - davidmolony/MESC_FOC_ESC at 96fb25afc07f31bedd5439b9273e76e75e7277ba
Referenced here: Endless Sphere Forum Post
Could you kindly confirm if this is the correct commit to start working with?
Also, I was really impressed to see that you’ve implemented HFI, MTPA, and field weakening all the more impressive given your background in mechanical engineering. Hats off to you! It's not only technically impressive but also inspiring for someone like me coming from a similar learning path.
If you have any suggestions or tips for someone starting to explore your codebase, I would be very grateful.
Thank you once again for sharing your work so openly with the community it’s an incredible resource and a great help for learners like me.
Warm regards,
BldcLover
Also, when I downloaded the project and opened it in KiCad, I encountered an issue. As soon as I opened the schematic and layout editor, a pop-up message appeared after that I see there is some schematic symbols are missing.
I’m not sure if this is expected or if I might be missing something on my end. Could you please let me know if there’s a specific setup or version of KiCad recommended for working with your project files?
also in kicad 3d view it look like this two mosfet are overlap to each other:
and inside the same project folder I found this image where only one mosfet is place did open wrong project?
I am using the kiCad 8.0.4 version.
Thank you in advance for your time and help!
Best and Regards,
BldcLover
Best and Regards,
BldcLover
I wouldn't simply copy this. To learn, you need your own path. You should seek to understand why things are as they are on devices that work, and then go your own way.
The project was made in kicad 6 and I have no intention to update it, it is how it is, my first esc 4.5 years ago. Every kicad update a load of incompatibilities and minor errors appear as they change the way it works and deprecate/update libraries that you just have to plug through. It has various oddities like the mosfet footprints being on top of each other due to extreme difficulty in sourcing parts back in 2020/21... Obviously you only fit one of them...
The mp2 is probably better. It uses differential opamp for example whereas my original esc was extremely cost optimised by using single ended internal opamps.
Look also at my GaN and IMS projects.
Read through all the firmwares, you'll learn different things from all. Stancecoke firmware shows how to optimise for tiny mcus and run in fixed point. Mine is intended to operate on multiple stm platforms (floating point ones). Odrive is for servo control, VESC tries to do absolutely everything but is incredibly complicated to understand... Open inverter uses a simpler MCU and at least last time I looked was quite low performance but they have support for much bigger inverters and induction motors and such... SimpleFOC shoehorns FOC into a platform it really shouldn't be run on...
They all have their merits and drawbacks.
Hi mxlemming,
Thank you for sharing your thoughts, it really helped shift my perspective.
You're absolutely right. I got so inspired by the impressive work you've done, as well as by projects like Stancecoke's and VESC, that I initially thought of just replicating them. But I now realize the value lies not in copying, but in understanding *why* things are the way they are. Each design is driven by specific applications and constraints, and that’s where the real learning happens.
At the moment, I don't have a specific application in mind, I'm just aiming to build an ESC for my cycle as a learning project. I'm starting by studying your design, and then I plan to dive deeper into the firmware across different implementations: yours, Stancecoke's, and VESC. There’s so much to learn from each of them, and I really appreciate the different approaches you all have taken.
Thanks again for making your work available it’s an incredible resource.
Best regards,
BldcLover
I have a couple of questions about the design:
1. INA181 Gain Configuration
In the schematic, I see multiple INA181 current sense amplifiers being used. Could you please let me know which gain variant (A1, A2, A3, or A4) is used in this design?
2. Hall Angle Calculation
In your firmware, during open-loop hall angle measurement , you inject a certain level of Id current with Iq set to zero and use
the Hall sensors to estimate the initial rotor angle. I noticed that you're using the center of the Hall angle range for this
estimation. I was wondering why not use the starting angle of the Hall state instead?
From what I understand, using the center value helps reduce the possible angular error compared to the start of the sector, since Hall sensors only indicate a 60° electrical range. But I'd really appreciate hearing your reasoning behind this choice.
Best regards,
BldcLover
Hello Everyone,
I’ve recently updated my schematic and would appreciate it if you could review it and share any suggestions or point out possible mistakes.
I’m currently in the process of selecting the MOSFETs, so that part is still pending. Due to budget constraints, I’m aiming to build a low-cost ESC.
I’d also like to confirm whether the Hall sensor signals are correctly configured and functional in this design.
Additionally, I would like to know if transistors Q3 and Q4 will function correctly when driven with 3.3 VDC??
Thank you in advance for your time and support.
Best regards,
BldcLover
