Just don't use WD-40 on plastics, especially styrenes; it can damage the surfaces, make them begin to be sticky, or decompose.
What's a better degreaser/cleaner? IPA doesn't seem like it'd be sufficient.Just don't use WD-40 on plastics, especially styrenes; it can damage the surfaces, make them begin to be sticky, or decompose.
You're talking about using the regular white bicycle lithium grease?would try the LM grease
Right, you could always just clean and re-apply occasionallyDrizzt321, to be fair to Tongsheng my 48V TSDZ2B which was a cheap new returned unit to PswPower, original owner it seems blew the controller's input side, fitted a new V1 controller and it's now running on my 29er. Anyway the unit was quite well greased up inside, now whether this grease hardens up after time is another question. As a retired engineer I am quite happy to open the drives up and service them if I hear any funny sounds. Do not know the Mobilgrease 28 but the white lithium grease should be fine, until I find out more will see how my LM grease works out, otherwise a water proof lithium grease.
seems excellent!Kluber Isoflex LDS 18 Special A Special lube is used for servicing the Onyx sprag clutch system in rear bike hubs, new one on me. Some thing to look at.
From this page, Tongsheng TSDZ8 750W 48V teardown, disassembly, the TSDZ8 now uses a pawl type gear on the pedal axle. but they still use the TSDZ2B style sprag clutch to let the crank gear freewheel from the motor.all that said, I know I'm late to this sprag clutch party and this might be fixed on the TSDZ8. but we shouldn't be replacing parts that dont need to be replaced at all. I speak for myself of course - I feel like my own ignorance about how these gears work has cost me $60. if I wanted a 100% slip-free riding experience I'd probably need a new gear every 4 months.
How do all of those do with Nylon, when some almost certainly will leak into the inside with the nylon gear? I think that's an advantage to the Mobilgrease 28, is it's nylon compatible.seems excellent!
- Vs. DT Swiss Special Grease (Red): This is a very close comparison. Both aim for low viscosity/drag. The DT Swiss is proven for its specific application and is almost "oily." The Kluber might be slightly more "grease-like" but with a very high-quality formulation. The deciding factor would be the exact "feel" or consistency of the Kluber.
- Vs. Shimano Freehub Grease: The Kluber LDS 18 Special A almost certainly has a lighter base oil and better low-temperature performance than the Shimano grease. If the Kluber is NLGI 1, it would likely be superior for the sprag.
Hmm that's a key point. It's also durable so yeah it's likely the best choiceHow do all of those do with Nylon, when some almost certainly will leak into the inside with the nylon gear? I think that's an advantage to the Mobilgrease 28, is it's nylon compatible.
