With the phase wires shorted, I think the torque should be a linear function of RPM.
Umm? What this mean about the torque capacity of the ME1507 at 1200 rpm?I think the torque should be a linear function of RPM.
Sure: 305A ac.Do you have a way to measure the current in the shorted phase wires?
Yes. Especially as I already have the ME1507 connect to a 1500A EZkontrol controller to test everything.You could try the second Leaf motor and see what happens. Seems like a lot of work.
But that probably not good as 61Nm at 1200 rpm should be 7.6 kW and I don't ever see more than 3 kW out of the battery.At 305A, it should be 61Nm.
I would like to understand why, but sadly I don't understand this.I don't think you can get more regen load than shorting the phase wires.
Set at 500A it was reaching near 500A.I wonder what kind of phase current you're getting when it's full braking.
That is because you have reached the phase current limit.Still, I clearly don't understand how rpm can reach 1760 with light load and drop to 600 underload.
You may be able to get slightly more by turning off field weakening and turning on MTPA
Thanks for all the good info!For the leaf motor you need MTPA
