rezystor1990
🔌 New-ish
- Joined
- Nov 18, 2022
- Messages
- 16
Will the new speed sensor from the "RS" engines be compatible with this board?
Hm, the encoder is placed quite isolated on the original PCB. There is much space to the neighboured parts. I guess this is to avoid interferences. Maybe you should do it in this way also....figured out the layout guys
You mean mechanical interference with the motor shaft cover? It should be fine as long as there are no tall part around the encoder. This yellow circle is the diameter of the motor shaft cover, as long as the parts whiting this circle are shorter than the encoder it shout not interfere with the coverHm, the encoder is placed quite isolated on the original PCB. There is much space to the neighboured parts. I guess this is to avoid interferences. Maybe you should do it in this way also....
As written in #25 already, you have to change just one line of code. For the break lever switch it needs some more modification, but not much.as long as you can figure out how to implement that torque sensor code
endless-sphere.com
So I hope they will respect the rules of open source development and publish their source codeIt loos like this guy already finished an aftermarket controller for Bafang M560
