Tabless design cylindrical cells tests
Looks like Varta in Germany is also producing tabless, appears to be a bit behind the Chinese manufacturers though:
Very interesting!
Worth a read: Porsche considers acquiring a stake in Varta battery subsidiary V4Drive - electrive.com
Their V21700-H50 could be interesting—though by end of 2025, there might be other interesting alternatives out there.
Let's see!
Interesting chart! I'm not sure how they're rating power density since the numbers on that chart are lower than their datasheet (UHP-26 has max specific power of 17kW/L pulsed). Designation also indicates only "High Power" vs "Ultra High Power".
We should see production 5Ah tabless cells with ~60-70A capabilities by mid-2025 with >5Ah pre-production sampling; it'll certainly be a tough market.
@thermal_runaway look, a pleasant surprise! ⚡
(Sorry @Pajda, it couldn't be helped!)
Seems like pre-production V4Drive 21700 5.xAh cells.
Batemo tested them at 18.8 Wh at C/10.
Nominal rating given is 5.40Ah.
Pretty solid competition to the P50B at the stage!
Though probably not available for purchase anytime soon...
V4Drive V21700HEP-5.X(A0) left / Molicel INR-21700-P50B right
Hmm color looks right bit it's missing some text
I unfortunately did not have much time to test but initial impressions are that it's about competitive with the 40PL (so is at least authentic, or someone is selling rewrapped 40PLs :p. Somewhat oddly seems to have higher DCIR at low SoC but equivalent everywhere else.
So the BAK 45D seems to be first tabless cell with 4500 mAh available on the market.
Yeah, BAK seems to be the furthest along here among the major Chinese brands especially in offering a wide range of capacities from 4Ah up. I believe they have been supplying OEMs since earlier this year based on vendors telling me the 40D and 45D were available as extracted cells (same with Murata VX40s), although these are fresh from factory.
EVE's tabless lineup (46xx aside) as far as I have been told is currently only planned to be the 3Ah 18650 and 4Ah/5Ah 21700.
I believe Tenpower has only announced a 4Ah, Lishen has their 4Ah/5Ah product plan. Although for both companies their reps have not been very responsive.
interesting, a bit different info compared to this previous info:
So it't 30Ah which is also not bad, but now I am confused because Pajda tested P variant and got 32Ah, shouldn't this E version have more? Also they are rated to 4.2V max charge after all, is that the difference (30 vs earlier 32Ah)?
Also looks a bit different compared to this pic:
1679630317529
I hope you have seen this, great results!
Incredible high cycle life if it continues decreasing linearly/logarithmically.
Mooch did again a great job. I asked 18650-21700.com site if they send me JP40 and AM3 samples, as they seem to be the only one distributor so far.
Wow. The AM03 looks to be a kickass cell.
Its voltage drop is considerably lower than a 35E/EVE 35V at the same current draw, which means there was a big resistance cut somewhere its its design.
Is it tabless? Possibly, but there are probably other improvements even though tabs are often a big bottleneck for HE cells.
So it went fast. Austin from 18650-21700.com answered me back promptly that it should be no problem to send me samples of JP40 and AM03 for testing now and samples of AM04 and AM05 in near future. :)
The available info about the AM03 is that it is an 18650 format cell with ca 4Ah @ 13.5Wh at 2C discharge. So definitely a very interesting contender in the HE category. 18650 AM03 - High Energy Cell with 8a Discharge Rate
18650-21700.com want to use their AMxx brand on the cells they sell and below is their roadmap. We'll see if they disclose the original cell manufacturers in the future as they did with the Ampace JP40.
More testing is ongoing but here’s some info on the cycle life of EVE 40PL cells available now. After 200 abusive cycles*** the run time/capacity of the cell only dropped 5.6%. Significantly better than the very disappointing cycle life of the (presumably) pre-production cell(s) @Pajda tested.
***5A charge to 4.20V (terminated at 500mA), 0-60 second rest, 30A discharge to 2.50V, allow cell temp to drop to 40°C-45°C, repeat.
