Whats everyone's opinion on these packs opposed to the Lipos ?
http://www.battery-matrix.com/DIY-72V15Ah-24S1P-LiFePO4-HEADWAY-BATTERY-PACK-KIT-40152S-cell-40152-cells-headway-lithium-battery-40152-headway-lifepo4.html
DIY 72V15Ah(24S1P) HEADWAY BATTERY PACK KIT
DIY Pack Includes:
1:24pcs 40152S 15Ah Headway Cells
2:1pcs 72V/24S Cell BMS constant discharging current:40A,Peak discharging current:120A(you can choose your need of BMS in our shopping BMS select)
3:1pcs 72V3A(87.6V3A) LiFePO4 Charger
4:24pcs Battery Bonnector
5:1pcs Red/Black 50A Anderson Connection (One is Connecting to the AWG 12# Silicone wire that is 50cm, Used for Discharging)
6:One is 45A Anderson used for Small Discharge Current
7:Two lines of AWG 16# silicone ,the length is 50cm(Color is Red,Black )usd for Charging positive,negative
8:One line of AWG12# silicone,The length is 30cm that used BMS to Battery B-
9:3pcs 6-6mm Diameter of the connection terminals,one is connecting to battery B-, One is connecting to P+.the tired one is connecting to the B+
10:1pcs jack female(1+,2-),is connecting to the charger
11:One meter no-lead environmentally solder (enough )
12:25pcs connection terminalsthat used to connect the BMS signal line and Battery
13:A sufficient amount of heat-shrinkable tube
