crea2k said:
Think I have FINALLY found two circuit breakers that tick the boxes for the amperage and voltage for DC :
http://www.digikey.com/product-detail/en/8345-C01A-U3M0-DB1A1B-125A/302-1303-ND/659650
and also
http://www.ebay.com/itm/CT1-B2-14-B10-A11-MF-100A-Circuit-Breaker-/330980766542?pt=BI_Circuit_Breakers_Transformers&hash=item4d0ffdb34e
Is 100A or 125A high enough ?.
I have been looking for something similar and found this on Amazon. (Solar suppliers have high powered DC stuff)
"100 amp 150VDC Panel Mount. 10,000 AIC Breaker Torque Value: 30 In-Lbs (3.4NM) Breaker and Busbar Torque Values All MidNite circuit breakers can be used at 100% rated current when mounted in a MidNite enclosure. Listed for AC & DC in US & Canada Size 3/4" wide, 1/4" studs for Electrical connection Weight 0.5 Lbs"
But the question still remains-this is a circuit breaker and not a switch and is not designed for on/off repetitive duty cycles.
