Doctorbass
Tonight i made some interesting discover about the Adaptto controller shunt:
I was discussing with Allex regarding the fact that our MAx-E controllers often dont offer to go as high as the 140A batt setting oin the Boost power profile. I got my two new version 14kW Max-E and one only allow max setting to 120A and the other to 123A!!!... but to get the 14kW at the recommanded max voltage(85V) it require more like 170A batt current... but it is impossible actually to set that value in the locked firmware
Also at high current the internal copper made shunt is ALOT affected by the temperature! At 100A current it raised up to 115A measurement on the display ! that's about 15% higher reading!... so if your shunt is hot, it will limit sooner the current and wont let all the current you think goes in the controller.
Here is our discussion:
I decided to test one to see if the current monitor is right. And it was off by about 3% ( reading 105A while it had 101A)
But to make it calibrated i had to set the Rshunt to 0.396 miliohm and it not can be set only to 121A !! so your theory is right
It's like the 140A target require to have a shunt that have the proper resistor. The 340 miliohm look right to get 140A reading.
Look like we have to add some solder to the shunt... like we did on the past infineon controllers... .lol to get appropriate reading.
here are the compilation of our max current setting availlable compar eto the shunt value that are set: ( Batt Amp and miliohm)
121 0,396
126 0,377
139 0,344
According to excel spreadsheet the predicted max current the actual shunt preset value has been calculated for is about 260A
I will have to modify a little bit the shunt to make it goes to 140A or more =) but i just worrie that the phase current calculation and protection might also be affected. I'll have to see with Jeka....
Oh.. I just opened the second 14kW max-E i have. The shunt is factory calibrated to 396miliohm and max battery current is 120A
This one is opened and i had a chance to measure the milivolt directly at the shunt at 100A and i measure 36 milivolt (= 0.36 miliohm.)
But hey guess what! I left the 100.0A continuous from my power supply on the shunt to see if it is stable. And NOT!.. the current reading that was 105A ( about 5% error) slowly raised to 115A !! after a minute! i would say that it was to about 60 celsius.
so.. just like any other controlelr that measure current with a shunt, as the shunt get hot, it lower the REAL current limit witch "help" protect the controller against overheat....
But hey! we like high power!! these shunt have to be cooled with fins!!
Here is a video of my investigations:
[youtube]q8Q_DJyMw88[/youtube]
121 0,396
126 0,377
139 0,344
