Thanks for the kind words.
yeah it looks nice, and it was nice to see voltage sag on a per cell basis....I guess it was an early version of the graph screen you now have on the Adaptto when using the BMS.
The LED checkers were just too inaccurate though, and I could never actually look at them closely enough during acceleration to see which cell groups were sagging more than others. They also liked to drain the first 2 cells slightly, which wasn't a problem if you only leave them connected when riding, but a bit annoying as it required more often balance charging.
I might still do it again as I have some more of the LED checkers which might not be as inaccurate, and it is still nice to see this info.
I think using a BMS is more valid when running high capacity 18650 built packs as you have a higher chance of failure running sooo many <3.5AH cans vs larger capacity LiPo setups.
I just recently got 8 x 10AH MultiStar packs to run in my Fighter. With only 4 bricks in parallel, the chance of one going bad unnoticed is a lot less IMO than with 10 or more 18650 cells in parallel.
That being said, a BMS is not going to stop a bad cell dragging a group down with it....it's just going to let you know if you happen to be paying attention to it. In notger's case, even if he had a BMS, if he wasn't keeping an eye on it and the bike was left sitting for a while, he could have just as easily lost that group of cells.
I guess my solution with the LED's is just the early warning part of a BMS without any cut off, etc...so the poor man's BMS
Cheers
Cheers
