AussieJester
1 TW
Jeremy Harris said:AussieJester said:You LEGEND Jeremy! saved me a few bucks buddy, is exactly what i need, i use a momentary switch to control the actuator
on the cruiser, i will buy this actuator from ebay soon as i finished this post THANKYOU for pointing it out... Servo City haven't even got back
to me regarding how to purchase so :: flips the bird to them:: tardy customer service pisses me off they lost a sale...
Happy to help, Kim.
That actuator also has built in limit switches, which means that if you're using its full travel you should be able to wire the switches in series with your 'up/down' switch and have the thing auto-cut-off at full up or full down.
Jeremy
Jermey
actuator reaches its end points, the button on the switch is actually physically pushed to the off postion by a piece of material on the actuator 'innards', very ghetto and i dont know if the actuator you linked me too is the same but i assume it would be? Would be neat to be able to control these electronically so the end points could be adjusted on both directions, was the sole reason i pulled the actuator down Recumpence gave me, to see
if i could alter the amount of travel haha...I am guessing the Servo City digital actuator can be more precisely controlled
http://www.servocity.com/html/heavy_duty_linear_servo__25__l.html
For my application though, the ones you linked to are absolutely perfect buddy...
Yes i could understand commutator failure due to overheating but as you say, this is user error and common sense tells you if the tool is getting to hot turn the thing off and let it cool haha, i would of thought hard woods would be more effort to router than ali too... Wont be stopping me in the future either way shall definitely grab some woodwork carbide tip bits to try next time
Thanks again champ
KiM
